The shift detents in a t5 are not the best. You can use a drill and make the detent plate have deeper detents, shim the detent spring, or find a stiffer spring on McMaster.Gonna crosspost from another thread I have:
Basically everything that could be wrong with my setup was wrong and resulted in horrible vibrations.
- T5 tailshaft bushing is worn out (leaking oil from the seal and introducing vibrations)
- modified driveshaft was out of balance
- transmission is probably still not in proper alignment
- pinion is pointed downwards
And on top of that I had the spicer center support which is super hard and was transmitting all of that into the cabin very nicely. I'm trying to power through here. It's been a bit discouraging also because The transmission keeps popping out of 5th gear after you get on and off the throttle a few times. You can see it move backwards each time I lift off the throttle. I'm going to try driving it without the boots (boot around the shifter assembly and the interior shift lever boot) and see if that's still happening.
The shift boot pulling the trans out of 5th is a real deal issue. Lots of fiddling with that to get it sorted.
