Turbobricks Forums
-   performance & modifications (https://forums.turbobricks.com/forumdisplay.php?f=13)
-   -   Holset hx35 oilfeed line (https://forums.turbobricks.com/showthread.php?t=354383)
Mr.Borrie 04-09-2020 09:07 AM
Can anyone tell me the oil feed line size I need for my hose.
The one off my Cosworth is to small, bonus points for link to an adapter I can use to reuse the garret cossie line
Photo:
http://turbobricks.com/forums/pictur...pictureid=4011
WTF99 04-14-2020 02:04 PM
An4 ans AN10 or better AN12
Mr.Borrie 04-14-2020 02:58 PM
Its an npt size I think ..?
Stiggy Pop 04-14-2020 03:01 PM
the oil inlet is m12x1.5
I'd run a -6 AN hose size for the feed and a -12 AN hose for the drain. Fitting that big drain hose is tough if you have a snaky header.
Mr.Borrie 04-14-2020 03:12 PM
Yes I got the return line AN12 with yoshifab block thingy
MasterCylinder 04-16-2020 06:48 PM
Yoshifab should be an-10.
Mr.Borrie 04-17-2020 04:04 AM
Ah yes you are right
Mr.Borrie 09-18-2020 04:18 PM
Going this way, is the block size also m12x1.5 so I can order the couplings for that side too?
Edit: it’s m14x1.5
