SkeTchy-MechAniC
- Jun 16, 2020
I'll be finishing this swap the weekend and thought i'd share this drawing with you guys. It's true scale, So when printed it can be used as a template. And when doing this swap you'd have to bend the taps a bit to fit the with of the pedal. I just bent them open, placed a 12,5 mm drill in between and bent them straight again in the vise. The pin that goes thru the paddle is slightly thicker on the suzuki one, you could drill the hole in the pedal to 10mm, Or use the volvo one with two adapter bushings ( Inner D8 Outer D10 With 4.2)
https://www.dropbox.com/s/l6lavm08voaspqw/volvo brake booster adapter plate.pdf?dl=0
