Old 04-07-2015, 07:16 PM   #1
HiSPL
HiSPL's Avatar
Default Are there any Poly Bushings for the 960?
I need to redo pretty much all the rubber under my car (96 960).
I'm hoping that somebody has made or found poly bushings for this app. Anyone? Bueller???
Beets taste like buttfeet.
Old 04-07-2015, 11:00 PM   #2
kendogg
V8 Guy
None, sorry.
kendogg is offline   Reply With Quote
Old 04-08-2015, 12:16 PM   #3
Hoggster
Hoggster's Avatar
I've heard some people fill the rear control arm bushings with windshield urethane. Those seem to be the trouble bushings on the late front ends.
Hoggster is offline   Reply With Quote
Old 04-08-2015, 01:35 PM   #4
benski
Post
IPD sells some poly bushings for the 960. I didn't bother to do the shopping for your specific application, but I know they at least have stuff for the front.
benski is offline   Reply With Quote
Old 04-08-2015, 04:42 PM   #5
Dree
Dree's Avatar
Default Stabilizer bar
Hi,
I know at least the front stabilizer bar rubbers can be bought in Poly. Make sure you buy the right diameter, because they're sold per mm difference (diameter of the bar), and measure your mounted bar, because they may change per car.
Left my old bushings, right the fresh poly. And yes, they needed to be changed
Dree is offline   Reply With Quote
Old 04-08-2015, 05:17 PM   #6
HiSPL
HiSPL's Avatar
Mine are rattling for sure.
Do you use a new bushing and fill it with goo? Or do you just spooge the goo into the old bushing?
Old 04-10-2015, 09:30 PM   #7
Greg Wong
I have tried to put the "window weld" in the bushing with no luck. I haven't heard of anyone else who did it successfully either. I scuffed them up pretty well, and washed them nice, but the second you put the car on the ground, the window weld just separates immediately. I don't know if it is possible to get good adhesion. Maybe if you heat the whole thing up when you do it?
Homepage
90 245 V8
07 V70 2.5T
Greg Wong is offline   Reply With Quote
Old 04-11-2015, 12:49 AM   #8
benski
Post
No use kanoodling around with band-aids. Get the real article, or machine it out of the material with the durometer of your choice.
Old 04-11-2015, 05:20 AM   #9
Moon_walk
i may have a solution for this .. it's in the works and not yet ready . does ned some cutting and welding but will solve this issue once and for all this is what it looks like
a spherical bearing with a polyreutan liner that is replacable and can be tightened aswell fully rebuildable
what needs to be done is to cut off the two cones that hold the arm in Place today
add a weldnut to the bracked and add a reinforcement washer to the brace when the ocne is removed
after this it's all bolt on
and this is what it looks
Moon_walk is offline   Reply With Quote
Old 04-11-2015, 12:37 PM   #10
benski
Post
Old 04-11-2015, 12:37 PM   #11
benski
Post
How may Krona for these darlings?
Old 04-11-2015, 12:41 PM   #12
Yea.... was going to rig up something similar... Big problem is the mounting studs as they have funky geometry... unless you dont mind cutting them off and putting new hardware in.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-11-2015, 12:52 PM   #13
Moon_walk
well the Control arms with bushings installed will be in the ~$200 region each
other than that a nut has to be fabricated and welded in Place and the factory studs need to be removed and a new bolt needs to be installed
the bolt in this application that i'm looking at is ~m16 or m14 with bushing
Old 04-11-2015, 03:13 PM   #14
HiSPL
HiSPL's Avatar
Shut up and take my money!
Old 04-11-2015, 06:52 PM   #15
benski
The road to higher performance is paved with more money...
Old 04-18-2015, 07:57 PM   #16
Turbosundance
Could that be used a road car for any length of time? Or will grist and debris wear it out quickly?
1991 744 B230FT - RIP
1998 S90
Turbosundance is offline   Reply With Quote
Old 04-19-2015, 02:00 AM   #17
Moon_walk
it should and one may also add dust cover of some sort.. still working on that one ..
but it's built for offroad racing and if being sligtly loose it can be retightned and when the day comes it's fully rebuildable
Old 09-16-2018, 11:12 PM   #18
Bolzen
Any proceedings on the new design, how did everything end up?
Bolzen is offline   Reply With Quote
Old 09-18-2018, 11:51 AM   #19
monty400k
Ive just bought some rear polybushed upper arms for my 960 from a guy in Latvia, he offers bushes for the whole car
monty400k is offline   Reply With Quote
Old 09-18-2018, 12:43 PM   #20
curiousCat
For the love of those afflicted, who and where???
curiousCat is offline   Reply With Quote
Old 09-18-2018, 10:05 PM   #21
Vincent Gagnon
Vincent Gagnon's Avatar
Well, now you did.
I've been told to put new bushing in the dishwasher before attempting anything with the windshield urethane.
Worked all right.
There is some bushings here, but it's stupidly expensive.
http://www.retroturbo.com/?product_cat=pubusehs
There is also a few here:
http://www.kgtrimning.org/superpro-b.../volvo/700900/
Member of TBCCS
Old 09-19-2018, 05:43 PM   #22
monty400k
Reinis Felsbergs on Facebook, has full 960 mk1 and 2 kits available, around the 1k euro mark, there is a lot of bushes in these!
Old 05-05-2019, 08:16 AM   #23
Moon_walk
well they are really a set of ballistic joints found here
https://www.ballisticfabrication.com...allistic-joint
i still have not had the time to mock it up in a car as the Project has been standing still for very long time
but it's moving finally and have a new interior coming in aswell as a full wiring from an s80 so .. eventually
