#801 |
![]() Glad you were able to get it sorted. Hopefully it stays on at the track/dyno!
Cult Person. Pissing in your Kool-Aid. |
#802 | |
![]() Atta boy
#803 |
![]() Looking good Sean, Glad you figured out how to keep a belt on there. Seriously impressive build man.
The guys at trackside motorsports on N Interstate know what they’re doing when it comes to modified Volvo’s getting a proper alignment, check them out. |
#804 | |
![]() Quote:
I have pushed this thing to the side for now, its in one piece, has new tires on it, belt seems to be staying on at least for now. It has an oil leak from the new cooler or lines somewhere but I havent looked for it yet. Its gonna chill there for now. Nothing going on this spring so nothing to really do with the car. Working on a foxbody notch now, should be fun.....getting the treatment that the volvo should have but I was too afraid to cut it up. So its getting 315's, flares and everything from the maximum motorsports catalog. Keeping the 5.0 and T5 in it for now. How is everyone doing through this crazy virus? Hope all my fellow TBers are holding up well and safe. Sean |
#805 |
![]() PLEASE please make a thread for the notch, sounds epic.
#806 |
![]() Join Date: May 2007
![]() Notch Fox Body is the best kind of Fox Body.
#807 |
#808 |
#809 |
![]() Is there a thread for it??? I assume you've seen Matt Farrah's old fox body?
You should let me "borrow" your KTM... |
#810 | |
![]() Quote:
Here ya go!! Yeah I have seen his car. I dig his podcast and what he does for the automotive industry, he has built an incredible brand. As far as the foxbody goes....I didnt like the bolt on look of the flares and the car never really did anything but go from shop to shop getting worked on. Matt even says it himself. He had nothing but issues with it and never touched it himself. I should probably sell the KTM to be honest. My knee is ****ed from my crash and I dont see myself getting back to hardcore trail riding ever again. |
#811 |
![]() I'd love to have a katoom to brap to my shop and home, we've got a 525exc we converted to supermoto and I've still got my 200exc, back in Alaska though. Maybe I can clean your shop floor for the next 100 years to pay off the KTM, haha.
Great thread too, reading it now! |
#812 |
Formerly 1983_242
![]() Fox came out sick! Well done.
1982 244-"Ivory Blanco" GM L33/5.3L, T56, Mcleod twin disc, Gen 2 billet 7875, 44mm gate, 2.50 Hot/Cold sides, LJMS Stg2 turbo cam, PAC springs, H2O/Meth, 9.5psi/@13*, Etc. |
#813 |
![]() Nice job at Hoodoo this weekend. Are you hooked yet?
#814 |
![]() Thanks its definately a work in progress =)
I am getting there, CAM is a tough crowd with some fast drivers, I think I am starting to get the hang of it a little bit. The tough part for me is how little actual seat time you get. And we got lots of runs at HooDoo....But to give up 2 and a half days and get less than 15 mins of seat time is tough for me and my always busy brain. Ill probably never be great at it as I love track time more. But I have been having fun. Aside from the Car dying I think the fox is a pretty competent car as it sits. I think I need to swap the A052 onto the 11" Wheels and get more contact patch and less shoulder bulge. But back to the scheduled programming. I have taken a break from the Volvo for some time now. Sometimes on these things you have setbacks. After fighting with the tune for a while I kind of threw in the towel for a bit. Frustrated that it was dying when coming to a stop, throttle control is not great, still after that big ass radiator having cooling issues, and battling a power steering leak. I managed to get the power steering line replaced and solved 95% of the leak. I took it out for a quick car meet a few weeks ago on the hottest day we have seen so far it was about 90 degrees or so. The car got way too warm. 215 sitting at the stop light is just too warm for me. So I started looking into the fans and shroud and found out that the fans are only rated for 650 CFM each......That means I only have 1300 CFM to cool this big turd. I found some mishimoto fans that are rated for 1650 each and still only an 11" fan but much deeper. I took some rough measurements and it looked like they would fit, but only by fractions of an inch. Fan came in and I drilled some new holes and prayed that it would fit. ![]() It clears by about 1/4" and has a ton more airflow. I have driven it a bit over the past weekend and it does stay much cooler now. Freeway temps are 176 to 185. Around town stop and go I have seen it to 191 or so but cools off. Not sure if this is the end all but its certainly better. Ill be curious to try it out when it gets warm again. Now the tune. Tuning around this Nick Williams Throttle Body and BTR Cam has been a total pain. The car dies or attempts to die when coming to a stop, also throttle responce is not what it was with the GM Throttle body. I guess the best way to describe it is Jerky. Going to take another stab at it with the tuner again this week if I can. I have to admit I am getting to that point with this car though that its pretty much done in my eyes. Might be getting close to the time for someone else to enjoy it. |
#815 |
Prius Owner
![]() Join Date: Jul 2008
![]() 215º is normal operating temps for these engines. Corvettes see upwards of 230º when on the track. Not sure what everyones worry about being at the temp. These's aren't SBC that need to be under 195º
93 245 LS Engine Swap Project |
#816 |
![]() Join Date: May 2004
![]() It's one thing if the thermostat is keeping it that toasty, it's another if not enough airflow is doing it. That's not a controlled temp, it's a problem waiting to bite you in the ass.
'63 PV Rat Rod '93 245 16VT Classic #1141 |
#817 |
Prius Owner
![]() But it doesn't explain everyones fear of running at stock temp for these engines. Whats the fear?
#818 |
![]() That's a different topic, but it's some more headroom for temp buildup when you get into some boostyness.
#819 | |
![]() Quote:
#820 |
![]() Sean, to better guide that belt, maybe add one or two idlers with flanges to help pick up any sudden slack, keep vibration and wander down?
If it is 6 rib, maybe try a Gates 36270 (https://www.rockauto.com/en/moreinfo...90705&jsn=2055). Here's a massive list of them http://www.gates.com/oreilly/PDFs/Pu...%20Listing.pdf . Same 6-rib pulley but with ribs: Gates 36100 (https://www.rockauto.com/en/moreinfo...15482&jsn=2059) HTH |
#821 | ||||||
![]() Quote:
From what I have read, the reasoning for the high temps has everything to do with emissions output and nothing to do with ideal operating temps. I am not sure Ill take the car out for another track day though so its probably not even worth me worrying about at this point. Quote:
Sean |
#822 |
![]() Have you tried to add some timing and give it some fuel below idle rpm to give it a stronger cushion to land on when coming to a stop?
#823 |
![]() Join Date: Jul 2009
![]() Get a oem application fan. Most aftermarket fans I've used have all sucked ass regardless of what they are rated at. My 2 row c4 rad has been good ever since I got the shroud situated on it, just a hacked up 940 fan. The Fairmont had a dual pass northern radiator and 91 for taurus fan and it never got over 180-190 no matter how hard I beat on it
1974 AMC Gremlin, lq4, 7875 billet, ss2 cam, 80e, 3600 stall converter, Holley Terminator x 1984 Volvo 245 1995 Porsche 993 2013 VW Passat TDI Last edited by cosbySweater; 07-10-2020 at 01:36 PM.. |
#824 | |
![]() Quote:
Good ducting and shrouding makes a huge difference. |
#825 | ||
![]() Quote:
Thread Tools | |
Display Modes | |
