Old 09-18-2020, 01:17 PM   #1
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Default Let's talk about the P3 B6304T4 engine
Howdy all,
I am shopping around for an engine to put in the 244 and I am interested in this engine. The bellhousing pattern, Crankshaft bolt pattern, and starter placement are the same as the whiteblock. The obvious difference is that all of the accessories are driven at the back of the engine. Obviously this is less than ideal. Before potentially blowing a band on an engine for testing purposes, I figured i would ask around beforehand to see if anyone has sought to or successfully remedied this situation by relocating the drive and the accessories to the "front" of the engine. At a very minimum, I only require the alternator and perhaps an AC compressor.
DNAsEqUeNcE is online now   Reply With Quote
Old 09-18-2020, 02:52 PM   #2
740atl
educator monkey
740atl's Avatar
the Poi did it years ago... I'm not sure if his Pbase is still open.
http://forums.turbobricks.com/showthread.php?t=69171
Old 09-18-2020, 04:08 PM   #3
DNAsEqUeNcE
†John3:16
Irony, I have the poiwagon here with me, lol. I mean in reference to the p3 SI6 engine, however.
Old 09-18-2020, 05:04 PM   #4
740atl
educator monkey
740atl's Avatar
My bad... I saw b6304 and got all excited.
Old 09-18-2020, 05:24 PM   #5
GTJordan
Been here for too long
GTJordan's Avatar
I don't think you'll get it front mounted.
There is no front crank pulley to start. Even if you pull the front plug out, it is an empty barren wasteland of nothing.
Do they actually have the same pattern? The starter on the si6 is under the engine, not under the intake like the white blocks
Old 09-18-2020, 07:29 PM   #6
Kjets On a Plane
Kjets On a Plane's Avatar
^This. If you want to come up with a sump & all.
Are LS undesirable model 3/4-ton 4L80E cosmetically challenged, but mechanically cared for trucks/vans & holley oil pans made of gold where you live?
Or S80s/960s for that matter?
Just wanna be different? (don't blame you/no shade/shame).
Given where all the accessories are, presumably you'd either have to custom figure out a crank pulley?
&/or basically eliminate brake booster/anything & everything near/around the firewall/entire front mcpherson-strut RWD engine bay/tube frame car Buchka fake racecar style? (props?)
How PSI a stock can support?
Always Be Crushing!
Old 09-18-2020, 10:13 PM   #7
Stiggy Pop
Stiggy Pop's Avatar
I’ve sniffed up this tree and there really doesn’t seem to be any reasonable path
'79 242
943 pickup
Old 09-19-2020, 10:32 AM   #8
DNAsEqUeNcE
†John3:16
Thanks for the input all. I like the engine, but none of this extra work is appealing to me.
Old 09-19-2020, 11:48 AM   #9
Stiggy Pop
Stiggy Pop's Avatar
It’s torquey, very smooth, sounds decent... it would be so nice in a brick!
Old 09-19-2020, 03:39 PM   #10
DNAsEqUeNcE
†John3:16
I see also that the volvo SPA 4cyl also accepts the m66 and the tf80sc. It is less expensive and has traditional accessory locations.
Old 09-19-2020, 04:23 PM   #11
JW240
All idiot, no savant
Well, the alternator is under the intake manifold.
A/C compressor is pointing in the other direction, above the transmission, driven by a short stretch belt.
The water pump and PS pump are on the exhaust side of the engine, also pointing towards front of engine. It's been a long time since I worked on that engine, so not 100% sure of the PS pump.
So from accessories standpoint, ditch the ac compressor and its OK?
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 09-19-2020, 04:32 PM   #12
DNAsEqUeNcE
†John3:16
That's a fair possibility. Perhaps it may be possible to add an AC compressor in the opposite direction into belt loop. It's very hot in Texas and retaining AC is important. If only 48 volt systems were more readily available, an electrical ac compressor could potentially be utilized.
Old 09-19-2020, 04:55 PM   #13
GTJordan
GTJordan's Avatar
I would be into a the Spa 4 Cyl swap (VEA/VEP). That would be interesting. Traditional mounting, the engine is TINY, just feed the mechanical high pressure fuel pump and you're good. A nice tune from MAXXECU.
Jordan
Old 09-19-2020, 05:01 PM   #14
DNAsEqUeNcE
†John3:16
Is it a direct Injection motor?
Old 09-19-2020, 05:07 PM   #15
GTJordan
GTJordan's Avatar
Yes it is. The high pressure pump runs on the back of the engine. It is fed low pressure. That is all.
Jordan
Old 09-19-2020, 05:13 PM   #16
DNAsEqUeNcE
†John3:16
Unfortunately there are no current plans to run direct Injection on Maxxecu. I have to stick to port Injection only. However, perhaps not, as I do have a syvecs unit from my mk3 focus RS sitting about that could be used. That however would increase the expenses, as I wanted to do a BMW dct as well, and use Maxxecu only for engine and DCT control. Using syvecs would save me from buying an ECU, however.
