Old 09-23-2020, 01:06 PM   #3001
mblue240
mblue240's Avatar
I'm glad it worked out so well, and thank you for the bottle of whiskey.
It was a joy to work on a car that is as clean and well cared for as yours!
Is that the standard price for a DP now days? I'll have to hit you up when I finally pull my +t off the shelf and install it.
-Michael
Tbricks build
Yep, Michael is right.
Old 10-04-2020, 07:58 PM   #3002
LC4CARL
Aero challenged
LC4CARL's Avatar
Still leaks. Replacing the o-ring and crush washers. What else can leak oil on this side?
@PDXvolvo on IG
LC4CARL is online now   Reply With Quote
Old 10-04-2020, 08:39 PM   #3003
MrBrown
MrBrown's Avatar
The pressure switch, head, Valve cover, oil filter/cooler, turbo drain, and Oil pan.
I know cause all of mine leak.
GhettoFab build thrizzie
Old 10-06-2020, 11:13 PM   #3004
LC4CARL
Aero challenged
LC4CARL's Avatar
Ha. Sweet.
The cooler thermostat to block O-ring was hard and brittle. Let’s hope that was the leak.
Old 10-06-2020, 11:37 PM   #3005
LC4CARL
Aero challenged
LC4CARL's Avatar
So. I think we’re more or less done on the “Boost the DL” / “Covid killed the car shows” turbo project. Best guess +/- $1,500 and two months. Could not have done it without Harald and Robert. Hopefully the leak is resolved. Will put her on the dyno for the third time next month. First time was 110 WHP as I recall, second 150. Sort of hoping for an even 200. Gotta have a dream.
Heading out to Leavenworth Sunday with the wife and dog, in an untested car. What could possibly go wrong?
Old 10-07-2020, 11:12 AM   #3006
MrBrown
MrBrown's Avatar
Harald and Robert are awesome.
As for your WHP, what injectors are you running again?
Old 10-07-2020, 07:53 PM   #3007
LC4CARL
Aero challenged
LC4CARL's Avatar
These:
Set of 8 OEM Bosch Fuel Injectors 30lb/hr EV1 0280155831
Seems to run well. Though it took some work to set her up for the eight injectors...
Old 10-07-2020, 10:48 PM   #3008
Centsableone
SNAFU - BOHICA
Centsableone's Avatar
Leavenworth KS? Don't even worry about it! I bought my 245 and the first drive I did in it was from Dayton OH to Memphis TN. No tools, no nothing..
Wait a minute... maybe I wasn't thinking straight.
Anyway, the result for me was a safe arrival so I hope you have the same.
(BTW I googled Leavenworth and see that there is one in WA state which is ONLY about 280 miles from Vancouver).
1983 245T, 1986 244, 1990 745T, 1990 245, 1982 4- speed 245D,
Currently: 1990 245 and 1992 244
Sale and Purchase Feedback
Centsableone is online now   Reply With Quote
Old 10-08-2020, 08:58 AM   #3009
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss. The last bit in the mountains is sublime. Should be awesome with the fall colors. One of my favorite events is the "Euromeet" car show that they usually hold in the summer.
Old 10-11-2020, 10:45 PM   #3010
LC4CARL
Aero challenged
LC4CARL's Avatar
Notes from the road:
90mph rip on an uphill truck lane. Speed is so easy now.
Side by side with an older WRX making engine noises. Second gear rip that caught him off guard. Wife laughing. Smiles and thumbs up at the next light from Subie man.
Still only 8 psi. Need to adjust...
Twisted the MBC. Spike to 14, settles at 12 PSI. Wide band showing low 11's.
Hit the entrance ramp in 2nd, gave her the beans, then 3rd.
"Jesus Christ" I heard somebody say.
Oh, that was me...
Old 10-11-2020, 11:58 PM   #3011
LC4CARL
Aero challenged
LC4CARL's Avatar
Still leaks oil...
Old 10-12-2020, 12:21 AM   #3012
Sounds like a Redblock alright
Old 10-13-2020, 01:55 AM   #3013
mblue240
mblue240's Avatar
Still leaks oil...
That's how you know the fluid levels are okay. Be concerned when it stops leaking.
Old 10-13-2020, 01:38 PM   #3014
LC4CARL
Aero challenged
LC4CARL's Avatar
That made my day...
Old 10-13-2020, 08:29 PM   #3015
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 10-14-2020, 07:56 PM   #3016
LC4CARL
Aero challenged
LC4CARL's Avatar
Home at last. Five hours one way. Car did great. Spectacular fall colors / mountain roads around Snoqualmie. Easy top gear pulls up moderate grades at 75. Shocks suck (under damped). New seats are a big improvement for the lower back.
Old 10-21-2020, 08:31 PM   #3017
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Chicks dig lower back support
Old 10-21-2020, 09:01 PM   #3018
MrBrown
MrBrown's Avatar
Broke back is where it’s at
Old 10-21-2020, 10:34 PM   #3019
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 10-24-2020, 05:24 PM   #3020
LC4CARL
Aero challenged
LC4CARL's Avatar
https://youtu.be/w2DsNWi-2U4
WG actuator line disconnected. Second gear roll on to 6k.
Not sure why the video is so blurry. If you could read the numerals, you would see that the boost will surge to about 15 psi and settle to about 12.
Old 10-24-2020, 05:34 PM   #3021
LC4CARL
Aero challenged
LC4CARL's Avatar
Another run. Same second gear pull to 6k.
https://www.youtube.com/watch?v=waTZtasvV10
Old 10-24-2020, 06:24 PM   #3022
Wilford Brimley
Not great...hey that's china for ya
Old 10-24-2020, 07:05 PM   #3023
patrickstar
patrickstar's Avatar
I can see my apartment from your first video!
1983 242 - 4.8/AR5
1980 242 - Daily
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 10-24-2020, 08:19 PM   #3024
LC4CARL
Aero challenged
LC4CARL's Avatar
Could that be the "problem?" I figured 15 psi would be easy for this set up. Maybe that's all she's got?
Old 10-24-2020, 08:20 PM   #3025
LC4CARL
Aero challenged
LC4CARL's Avatar
PM me your address and I'll send you the bushings.
