![]() Looking to put a T6 in my 164, and also retain the power steering. I've seen that the whiteblock 240 swaps will work with the stock 240 ps rack.
How different are the pressures between a 240 ps rack and a 140/160 ps rack? Close enough to run the T6 ps pump? Does it really matter? Looking at you RWC. |
†John3:16
![]() Join Date: Jan 2009
![]() run it
![]() Yeah, probably just going to hook it up and see if anything explodes
#4 |
![]() The 164 power steering box (not a rack) is driven by 85bar/1230psi
I prefer less. If I remember right the whiteblock psp is with 100bar/1450psi, the car feels soft, too soft. regards, Kay |
#5 |
OEMplus++
![]() Join Date: Aug 2003
![]() the 850/960 saginaw TC pump uses the same pressure control valve as the 91-93 240 saginaw TC pump. Max output of 1200psi. I just went through this exercise. I think the later ZF pump off the RN engines is higher like mocambique mentioned.
