![]() Long shot maybe, but does anyone have a base map for the b230ft. I have the ecumaster emu standard, standalone ecu installed and hope to get it running soon.
Thanks All |
#2 | |
Owner: DeathWagon
![]() Join Date: Jul 2005
![]() Not likely going to find that.. I assume you are wiring it in and its not a PNP ecu.. I have tuned a few cars using the EMU ecu and its a decent piece but as far as volvo base maps go I seriously doubt you will find one here.
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar ![]() 93 245GL Street Beater ![]() |
![]() Are you looking for a timing and VE table? Or all of the settings?
#4 |
![]() Custom loom, fair enough was hoping for the easy option but not the end of the world.
I'm using the Crank sensor for wasted spark. Is there any other sensors missing on the stock b230ft that I might need for a good map? |
#5 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() you may want a real tps vs the switch that comes OE, and you'll need an air temp sensor as well.
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! |
#6 |
![]() and a map sensor if it's not built in to the ecu. just now getting it wired up I take? first time with a standalone?
#7 |
†John3:16
![]() Join Date: Jan 2009
![]() I hang out at ECUmaster all the time (basemap dev for new PNP's), what can I help you with? what sensors and the like do you have hooked up?
#8 | |
![]() Quote:
So the standard b230 sensors all hooked in, lambda on the Downpipe, Crank sensor, knock, pretty sure air temp too |
#9 |
![]() I have a b234f and couldn't find any basemap for EMU for volvo engines. best bet is to contact any local tuners to help with startup.
I would also suggest changing the crank angle sensor to a hall type if you have a dogdish flywheel. Had major issues with EMU reading the stock VR sensor. Also a Head mounted Cam angle sensor is easily adaptable from an MX5/DSM. their optical/hall cam sensor has pretty much identical splines to fit into the head. Only needs and adapter plate, that would space it out properly. |
#10 | ||
![]() Quote:
Mostly looking for suggested cold start and warmup, the rest I can sort out.
1993 964 1996 Dodge Dakota 5.2 4x4 daily driver 1988 Vanagon GL Quote:
#11 |
![]() https://www.google.com/url?sa=t&sour...j166qTva2VM27d
Here is a Finnish thesis work with basemaps for B230F+T |
#12 | |
Turbo, what?
![]() Quote:
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
#13 |
![]() I'm very interested in seeing this come together as well, I've got an emu classic on the shelf I'd like to use for a project but have absolutely zero clue on the initial setup
#14 |
bigpimpin740t@yahoo.com
![]() Base map is easy as could be, my first ms started with loaded 350 settings
85 744 Turbo F+T big valved531, stg5 cam, msns, m47, sways, bills, 53mm t3/t4 9lb flywheel, dual 044s, 80lbs, npr og |
#15 |
![]() VE and spark map will resemble the tq curve of the cam, tq peak will be fuel peak and u can run up the timing and more boost after the tq peak as it’s much less likely to ping as cyl efficiency drops and rpms continue. U can use this to flatten the falling output curve. If this makes sense I’m might be a bit buzzesy
