Old 09-14-2018, 10:41 AM   #1
jvluntzel
Default AW71L Feels "laggy" Help!
Hi All!
Specs:
1991 Volvo 740 base Regina with a 94 940 (edit..maybe 95 960 or smth else...trans has AW71L stamped on it) turbo engine and trans swap. Automatic
ever since the swap my trans has done this odd thing where if I put the pedal to the metal from a stop the engine loads up and the car moves slowly until it gradually gets to around 3000 rpm then she takes off like a bat outta hell.
When doing part throttle it is not as noticeable but it still does it when below 2500-3000 rpm. Shifting is nice a firm, downshifts well. Everything works great except that....and Its really annoying for out of the hole acceleration and whatnot.
HALP
jvluntzel is offline   Reply With Quote
Old 09-14-2018, 11:10 AM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Sounds like a turbo trying to spool to me..
-Stephen
#mclovethesenuts
-My car: White 1991 244, 308k miles. B230F LH2.4, AW70, R134a retro, Coronas
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
Old 09-14-2018, 11:16 AM   #3
white855T
If you got the trans from a 940 turbo, it will be an aw71. Did you do the accumulator mod?
Buyer/Seller Feedback
Old 09-14-2018, 11:44 AM   #4
iHateVolvoPeople
Sounds like you could be mechanically mis timed
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
90' 745T AW71
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
Old 09-14-2018, 03:15 PM   #5
jvluntzel
I have a boost gauge and when it is loading up its making positive pressure. Its a 13C. I fart and it spools.
It says AW71L on it. Maybe it was a 960 turbo? IDK. The car was in a junkyard and said 1995 and there was no boost gauge in the cluster. Wastegate pressure was 5 psi.
As in flywheel position? FML if so. It cant be out much if thats the case because in all other situations it runs like a dream. Idles nicely as well.
IDK if its possible for it for the flywheel to be the problem...There are 8 bolts holding the flywheel meaning one off would be 45 degs off! Maybe more possible of distributor position?
Thoughts appreciated :D
Old 09-15-2018, 02:59 AM   #6
iHateVolvoPeople
No sir I just meant cam/crank timing in relation to each other. I have timed a redblock like 1 tooth off and it idled glass smooth but did what your car was doing. I’d floor it and it would spool but felt like it had 0 power. Mine never really ‘woke up’ though, but was a bit better in the high rpm range.
It would be worth your time checking timing IMO, it is pretty easy to do.
Old 09-16-2018, 01:11 AM   #7
Mbeas96
Mbeas96's Avatar
+1 on the cam/crank timing. I put a IPD turbo cam in and misaligned the cam gear 1 tooth forward? I think it was forward one tooth, anyways it had no power. At all. I didn't let it get past 3k because I knew something was off. Idled and started perfect. Ran fine, but no power. Changed the cam timing and it was a whole new car
