Old 09-16-2018, 02:03 PM   #1
Jack
Banned
Jack's Avatar
Default cold start fuel line leaking - B230
replacing hG on a friends car. Car is almost back together. Cold start fuel line is leaking at the line/connection spot. How do you fix this? cut and slip on after heating it up or...
Thanks
Jack
[IMG][/IMG]
Old 09-16-2018, 02:15 PM   #2
iLoveBeingTeaBagged
Are you sure it’s not leaking where it 'tees' off? Looks like it’s bent.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
iLoveBeingTeaBagged is offline   Reply With Quote
Old 09-16-2018, 02:19 PM   #3
Jack
Banned
Jack's Avatar
Originally Posted by PromiseRing View Post
Are you sure itís not leaking where it 'tees' off? Looks like itís bent.
Thatís why I said where itís leaking
Old 09-16-2018, 02:35 PM   #4
iLoveBeingTeaBagged
That’s why I said where it’s leaking
You’re probably just blind. Anyway I’m not sure if it’s metal underneath that or if it’s just press fit rubber. Someone knows. But I don’t and neither do you.
Old 09-16-2018, 02:36 PM   #5
white855T
If it's leaking at the hose you can cut off the nylon line and replace with 1/4" fuel hose. Also get the correct fuel line clamps.
Buyer/Seller Feedback
Old 09-16-2018, 02:37 PM   #6
white855T
Under the nylon line is a metal barbed fitting.
Old 09-16-2018, 04:20 PM   #7
Jack
Banned
Jack's Avatar
Mcfail ring. I know it’s metal under wasn’t sure if you have to heat the hose or if my man hands can get it on the tip if I cut it
I didn’t have luck in an 850 which is what I asked
Thanks guys will just tury it
Old 09-16-2018, 04:43 PM   #8
durk80
durk80's Avatar
I accidentally tore mine off. After many searching I found one of these options to fit. Sorry I don't remember which one it is. It is from McMaster-Carr. It was like 14.00 with shipping.
[IMG][/IMG]
Good as new! I put the barb and the tubing in boiling water to soften it.
If that is your problem, which it might not be. Good luck!
durk80 is offline   Reply With Quote
Old 09-16-2018, 04:46 PM   #9
iLoveBeingTeaBagged
Mcfail ring. I know itís metal under wasnít sure if you have to heat the hose or if my man hands can get it on the tip if I cut it
I didnít have luck in an 850 which is what I asked
Nah I wasnít talking about a barb, I meant the line running to the injector. Wasnít sure if it was just rubber. My bad yo
Old 09-16-2018, 05:22 PM   #10
Jack
Banned
Jack's Avatar
H8
Itís plastic
Old 09-17-2018, 03:23 PM   #11
Boiling water may work. Or a heat gun. Probably don't wanna use a torch...
Lots of threads on repairing kjet fuel lines-same.
Old 09-17-2018, 08:53 PM   #12
300+hp on the shelf club
If the plastic hose is in good shape and it is just leaking from under it. I just put a hose clamp on there and that usually takes care of the problem. Otherwise it becomes a replace the plastic hose with the above processes.
Old 09-17-2018, 09:55 PM   #13
Jack
Banned
Jack's Avatar
it's right in the middle.
posted a wanted ad
