beepee
how hard can it be?
- Sep 25, 2008
- Southern MD
Vehicle is a '90 740 Turbo. Currently I have two AW71s, one is in-car and one is on the floor. Both have issues.
Transmission #1: Is in the car, has the accumulator mod done to it... but it has issues. Overdrive is shot. It's not the solenoid/wiring, it's not the kickdown cable. It does shift into overdrive. However, it will slip out of OD and back into 3rd with even slight power. It can't even maintain 55mph on level road without dropping into 3rd. Has had issues with OD since I bought the car.
After the accumulator mod, more issues showed up... but only when the trans is warm. When warm, the car will creep forward in neutral just like you are in drive. Reverse is even worse; the car won't move in reverse without lots more power than necessary... sometimes I get into boost in reverse . And, when letting off the accelerator in revers the car immediately stops. It's quite like trying to reverse with the parking brake on. I am still DDing it lately and it's been fine, but I know it's a ticking time bomb... (I do have another car!)
Transmission #2: is on the floor, in pieces, from an '87 240 I believe. As far as I know, the transmission was good until I attempted to do the accumulator mod on it and one of the valve body gaskets disintegrated on me (the original idea was to mod this one, then do a trans swap. After I broke it, we did the mod in-car at don beyer on the lift).
So, my question: Should I buy the $80 RockAuto.com rebuild kit and try to rebuild the trans on my floor? Or, should I go pull another one from the JY and try my luck there? I have the service manual that was posted online, so I think I could rebuild it myself.... but I'm not sure if it is worth the hassle.
And... NO, I don't have any problems with a missing third pedal. There is a holset in my future and I don't want to have to go through the hassle of putting a T5 in a 740.
tl;dr: Rebuild aw71 myself or pull one from the junkyard? T5/manual trans not an option.
EDIT: more to the point, does anyone want to share their experience with rebuilding the AW71? Is there anything that can be done to make it more awesome than the accumulator mod?
