- Sep 18, 2002
What is everyone doing for radiators?
Lately it seems my radiator is not up to snuff. It could be ducted a little better so I will try that and some water wetter, also I am using a V70 fan but only using the low speed setting, so I will try the high instead (IPD HD Nissens 3 row rad).
But aside from that, under fairly sustained, but relatively low speed, hoonery my temps climb pretty hard. I think the slightly more responsive turbo means I ran rip in and out of boost quickly at low speeds. Freeway pulls, or even a quarter mile run, would be fine. But doing tuning where I do pull after pull through 2nd gear starts to cook it.
Has anyone used and "GM style" rads? The inlet/outlet are in the right spot....
