Old 09-17-2018, 06:46 PM   #1
prometheus_aflame
Default 1990 245 DL, K10042 instrument cluster compatibility
I recently purchased a K10042 cluster on ebay that was rebuilt by Wagonmeister in California. Cluster was in good shape. I do not have a tachometer wire in my wiring harness. The odometer doesn't move and the seller is reluctant to refund me.
I currently have a K9800 cluster in the car that I've repaired myself (backlight issue) and it's back in the car.
Is this cluster compatible with my car?
prometheus_aflame is offline   Reply With Quote
Old 09-18-2018, 03:53 PM   #2
prometheus_aflame
Car is a 1990 Volvo 245 DL wagon, NA
Old 09-18-2018, 10:23 PM   #3
An automatic would have the K9800 cluster and a manual uses the K10042 cluster. It'll be off a bit but isn't a real major issue. Just check the speed difference on your GPS or one of those radar speed signs.
If you replace the odometer gears in these speedometers. I suggest replacing both gears at the same time for maximum chance that the gears will fix it and keep working.
