93 244 idle problem after warming up
About 4 minutes after starting 93 244 2.4 starts to idle like this: See attached youtube video.
She has been to two different mechanics, both claiming to be Volvo specialists, over the past month.
1st mechanic "who said he fixed it" said that there was a ground problem with a wire, that's why I had the volt meter on it. I was seeing if there was a drop off before the idle problem. Doesn't seem to be the problem. I was getting 13.78 volts and it only starts dropping after it starts to stall.
The idle issue will get progressively worse until it stalls completely if left alone.
Any thoughts on where I should start. I've tried known good MAFs, Idle Air Valve, and Fuel pump relays.
https://youtu.be/GhplZIh0EH8
