MadDog_945
Våga Vägra 8V
- Apr 25, 2006
- Lower Saxony
Hi,
Are there some people out who could post some pics from their cams on TDC without a cover?
I don't have a Cover so i cant check if the timing is right and the method i used to align them seems quite wrong..
I used the embedded pin on the valvecover and looked down from above.. but the mark in the cam should point on 12oclock to the sealingsurface.. if you do so the pin on the cover becomes so much useless...
Im confused... btw.. due to this i was 1,5 teeth off timing.. argh -.-
