thessejway
It Never Ends
- Dec 10, 2015
- Toronto, Ontario, Canada
Am I correct in believing that the fluid reservoir from the brakes is shared as the reservoir for the clutch on a manual 940? And you connect it by snipping the end off the nipple on the bottom right of the image below?
If so, where can I find that hose that runs from the master cylinder to the reservoir
If this is not the case, what is the reservoir that is used for the clutch?
Cheers,
Cheers,
