Pdx dl
The DL in its native environment: On a jack stand.
New ATP actuator has a MASSIVE spring in it.
In order to line everything up, we had to re-clock the turbo. Which sucked.
Well, on the positive side we have absolutely confirmed the cause and origin of my low-boost condition. On the negative side, I am apparently a very slow learner when it comes to the functionality of the MBC. For whatever reason I believed that I should over-spring the target pressure, then bleed it off with the MBC for fine-tuning. Obviously the inverse is true.
Do you think 25 psi is too much for an M47?
:omg:
Can you do me a huge favor and post a picture of the entire PCB of that 591? There is a chip on the top right I cannot for the life of me figure out what it is.
