Steps forward, steps back...
Got the RX7 brakes installed with new pads and 940 rotors. The rotors have to be drilled out to clear the shoulders of the 240 wheel studs; not a big deal but worth noting. I know this has been done a millionty times before but I couldn't find a comprehensive guide to the RX7 conversion so that was a surprise. Also had to trim the backing plates, but didn't think to do that until after the strut was built and installed; oh well. Struts are installed with the ipd springs and Billy HD dampers. New wheel bearings in the original hubs.
I had a hell of a time bleeding the system. I replaced the master cylinder with a new Centric one as well, and a new reservoir - it would've been rude not to. Of course the old original brake components looked terrbile, but the system was bled perfectly and always felt great. Now that I opened up the system and replaced stuff, we have issues. "You touched it, didn't you." For the RX7 calipers I first deleted the front-most brake lines on each side shown in the photo below, not realizing that this left me with both front calipers being on the same circuit - whoops.
So I moved the passenger front hard line up to the front circuit, which helped things. Do not plumb your single-circuit front calipers as I did above!
Still couldn't get one of the rear calipers to bleed at all - zero fluid movement. New rear brake hose fixed this. Old hose must've been swollen shut which I've heard of but never had the pleasure of experiencing firsthand.
Using my Motive power bleeder normally makes quick work of brake bleeding; this time wasn't so smooth, as you can gather. Last night I had a 30psi brake fluid explosion all over the engine bay when one of the power bleeder soft hoses burst. I was following the greenbook procedure as much as possible, trying to run very high bleeder pressure to get the master cylinder fully bled. It still had some air after bench bleeding several times.
Anyway - brakes are finally bled enough to drive, new tie rods in the front, adjusted toe (ish), Adjusted panhard rod as much as possible, took the car around for a first drive. I got a slight rub at the passenger rear fender lip as expected. This will need some slight fender adjustment and more panhard adjustment.
On my way to work this morning, I heard something that sounded like a jackhammer at low speed somewhere nearby. Windows were down but I didn't see any construction crews working. Foot off the throttle - jackhammering stops. Back on the throttle, giving the engine some load - jackhammer starts again. Crap.
I limped it into work and found an oil explosion all over the engine bay. Oil level was just topped off this morning. Leak was coming from the filler cap, so it's blowby. What's the over-under on a broken piston ring? How about a broken ring land, or a dropped valve? Going to investigate soon. Davis is looking unlikely at this point...for this car. I'll be there regardless.
