Old 04-07-2008, 01:38 AM   #1
WagenSport
WagenSport's Avatar
Default 90' 760T 15G mini project
As some of you guys might have read in the Performance Modification Fourms, i overheated my engine tremendouly and ripped my headgasket a new a**hole. Figured i would move my thread over to this section since it was more fitting. At the moment I'm still in the tear down stage. Going to pick up the 15g turbo, browntops, and 4bar FPR from the pick and pull yard this week. Right now the engine is at 215k, the plan is to install all of the following items, move the AFM downstream of the greddy bov, and start a tune. Oh yeah, and now that i know about this "fuel cut switch" for higher boost levels I shall hunt it down and remove it. No idea what my fueling will support but iam hoping to run a steady 15psi, and possibly higher for "track" runs and such. Otherwise i already ordered and recieved most of the following.
Stage 0
+Elring headgasket set
+Waterpump and themostat
+Stabilizer Bar bushing ( one is missing )
+Timing Belt Kit
+Red/Clear/Clear/Red tails ( right tail was missing some lenses and wouldnt pass inspection )
+225/60/15s for the rear since i burnt off most of the rubber on the previous tires running the 13c at 15lbs.
Performance
+Reclocked 15g
+Bosch Browntops
+Turbo Caravan FPR
+A/F Gauge
+8mm plug Wires
+Hard Charge Pipes 2.5"
+Ebay 28x9x2.5 intercooler
+Greddy Type RS Mounting tube (2.5")
+Greddy type RS ( already owned )
+Volvo electric fan kit
+255lph fuel pump
+Cat test pipe, magnaflow muffler, straight pipe for the rear muffler ( going to go 3"TB but no funds for such yet )
Hoping to complete the job this week, unless the head is warped, then the project will probably go on several more weeks due to funds. If the head is getting rebuilt its getting done right with oversized valves and the IPD cam and gear.
Wyotech 05'-06'
Major= High Performance engine and custom chassis fabrication
1990 215k 760T
15G build in progress... http://www.forums.turbobricks.com/sh...89#post1722489
2001 1.8t Jetta
APR 93/100 oct. Chip ( 20 psi )
3" dp to stock exhaust
http://myspacetv.com/index.cfm?fusea...ideoid=1037037
http://myspacetv.com/index.cfm?fusea...deoid=18819786
WagenSport is offline   Reply With Quote
Old 04-07-2008, 01:46 AM   #2
WagenSport
WagenSport's Avatar
Oh yeah also forgot I'm going to clip the springs in the front while its off the road, to level it out a bit, if not have the front dip down a little lower. I like the Positive rake look. Here is it pre work- ( Ill have some under hood shots as i go )
Old 04-07-2008, 01:50 PM   #3
WagenSport
WagenSport's Avatar
I like what the UPS man had to offer today:
Old 04-07-2008, 11:03 PM   #4
Brandon
Brandon's Avatar
I love fast wagons, they make me all giddy like a school girl.
Originally Posted by golgothan
Here is what you do to seal the deal, text her a picture of your nut sack stretched over a pine cone. I don't know why but girls totally dig it.
Brandon is offline   Reply With Quote
Old 04-08-2008, 03:20 PM   #5
stylngle2003
stylngle2003's Avatar
that interior looks immaculate! nice work...i like the style you're pursuing
-Billy
Volvoless for the first time since 1990...
2002 Toyota Avalon XLS (comfy gradma car)
1996 Chevrolet Tahoe LS 2WD (hauls ass)
1990 Mazda Miata (track toy)
stylngle2003 is offline   Reply With Quote
Old 04-08-2008, 04:35 PM   #6
WagenSport
WagenSport's Avatar
Thank you, I always enjoy sorta the OEM plus styling/tuning. I was wondering if any of you guys could give me some ideas or tips to think about when installing my A/F gauge, i dont want to just slap it somewhere stupid. Ive been thinking about cutting a 2" circle in the vent that is above my boost gauge, and installing it there. I will lose functionality of the vent though which will suck. Got the idea from this audi gauge pod...
Let me know if anyone has any better ideas, i dont want an A pilliar pod!
Old 04-09-2008, 12:15 AM   #7
WagenSport
WagenSport's Avatar
Did a little bit of head work today. Got a bit carried away, didnt even completly clean the head up much yet, or check the mating surface to be flat. Sounds like tomorrows job. (3 of 4 exhaust ports, opened up "slighlty"
Old 04-16-2008, 02:14 AM   #8
WagenSport
WagenSport's Avatar
What sort of valve spring compressor do should i use. Been seeing several types. Does anyone know if the autoparts stores rent them?
Old 04-16-2008, 03:26 PM   #9
stylngle2003
im doing my boost guage like that omori vent pod. it won't be too hard, and i may retain the vent if im sneaky. ill post pics when i get to it
Old 04-18-2008, 04:14 PM   #10
WagenSport
WagenSport's Avatar
That would be terrific. Glad to see someone else had the same idea. I might start with the vent pod tonight, the engine work is at a stand still until i get some parts and tool. On a Side note, install the r/c/c/r tails today:
Before :
After:
Old 04-18-2008, 04:19 PM   #11
WagenSport
WagenSport's Avatar
Oh yeah, also got the 255lph pump in. Took a little modification, but installation was a breeze. Simply had to take a dremel with sanding wheel, and take the bumps out from the inside of the pump holder. Once they were gone it slid right into the mount firmly. Installed new fuel sock, and had to splice pwr and gnd wire to fit the new connector.
Old 04-18-2008, 10:16 PM   #12
turbowagoneer940
turbowagoneer940's Avatar
easier to work on the fuel tank in a wagon, isn't it?
nice project!
turbowagoneer940 is offline   Reply With Quote
Old 04-21-2008, 08:39 PM   #13
WagenSport
WagenSport's Avatar
OK question/ opinions wanted. I want to make my blow off valve downstream of my AMM. Here is my proposed set up. Before the intercooler. Basically it would go, short pipe from compressor/blow off/ amm/ intercooler. Will this work out, or will i be screwing with the AMM having the blow off valve so close?
Old 04-21-2008, 09:11 PM   #14
ikyikthe1st
the BOV needs to be where the pressurized air is, not before the turbo
such as after turbo, before intercooler; or after intercooler, before throttle body
ikyikthe1st is offline   Reply With Quote
Old 04-21-2008, 09:22 PM   #15
WagenSport
WagenSport's Avatar
Oh yeah, does anyone know a good way to compress the valve springs without the tool. I rented a tool but it doesnt work on the volvo head since the springs and retainers are more recessed. Any ideas?
Old 04-21-2008, 09:23 PM   #16
WagenSport
WagenSport's Avatar
As i posted the order i was going for is TURBO, short pipe to bov to amm to intercooler. Sorry if i left something out previous.
Old 04-21-2008, 11:46 PM   #17
Manbeard
#helpbrock2k16
Manbeard's Avatar
love those tails....they make the car look like a different car!
2012 tdi
Manbeard is offline   Reply With Quote
Old 04-22-2008, 01:38 AM   #18
stylngle2003
+1, they look especially great on the black/chrome combo. very brand-new mercedesesque
Old 04-22-2008, 10:15 AM   #19
SteveMD
Membro
SteveMD's Avatar
In the past I have bolted an oxygen sensor socket to a standard valve spring comressor and it worked ok for disassembly. I have since found a hard plastic or nylon adapter that looks somewhat like the O2 socket but is designed for OHC valve spring compression. I can't recall where I got it, though. Search on the web.
SteveMD is offline   Reply With Quote
Old 04-22-2008, 11:31 AM   #20
MrBill
fige=500Dollar Mistake
MrBill's Avatar
im not so sure I am reading this correctly.
The MAF must go before the turbo.
The BOV must go on after the turbo to vent the pressurized air.
General consensus is post intercooler, but I've seen it everywhere with no bad effects
Originally Posted by grnmachine02 View Post
Someone say crazy rays?
93 245 - Kaplhenke Shortened coilovers with adjustable Koni Reds, adjustable rear spring perches with revalved bilstein S-10 shocks. Turbo 2.5 motor in the works.
10 v50 - Unobtainium T5 R-Design AWD M66
Old 04-22-2008, 02:34 PM   #21
WagenSport
WagenSport's Avatar
Why must the AMM go before the turbo? Would i see any ill effects placing it after the turbo. It seems like some guys on the have been moving the amm to right before the throttle body, but i dont want to extend the wires. I got some play room with the AMM wires now after unsheathing them from the rubber insulators, but i just want to have the air metered correctly. So your saying i CANNOT do the setup with the blow off valve then the maf in that order after the turbo?
Old 04-22-2008, 09:17 PM   #22
WagenSport
WagenSport's Avatar
Well i got my first set of valves out using 2 spring clamps to hold the head to the table, a chunk of wood to hold the valve in place, and a bar clamp pressing on a oxy sensor socket to compress the spring. Worked very well. My dad was giving me a hand, and thought that maybe he could cut a peice of 1x1 wood into a better tool, so he did. Not sure how its going to work guess ill find out later when we use it.
Old 04-28-2008, 07:59 PM   #23
WagenSport
WagenSport's Avatar
P+P progress...
Havent polished yet, just opening up the ports. Photos have exhausted manifold gasket for demonstration purpose.
Prior to port matching:
After Port matching ( could still use a little neatening up ):
Old 04-30-2008, 02:57 AM   #24
760T man
Phillip Mamouf-Wifarts
760T man's Avatar
Location: Bettendorf, IA, when I'm not EASTBOUND 'N DOOOOOWN LOADED UP 'N TRUCKIN'
Dude it's absurd how much better those new tails make the back of that thing look.
Nice car, man.
You're doing everything I wanted to do to my '90 764ti. RIP...
a '90 765ti, an '84 244ti, and an '18 780
Turbocharge it, and instead of the typhoon, or syclone, we will call it the “light breeze” -mrsam740 referring to the Oldsmobile 4.3 diesel
760T man is offline   Reply With Quote
Old 05-11-2008, 10:44 PM   #25
WagenSport
WagenSport's Avatar
Finished getting the head back together, didnt have time to order some extra powder for the gun, so i ended up just using engine enamel to coat the valve cover, nuts, cam gear, and and couple other odds and ends. Here it is fully assembled with the 13c.
