Old 05-13-2008, 03:54 AM   #26
WagenSport
WagenSport's Avatar
Got the head/turbo/manifold, new water pump and intake manifold back on today with all associated gaskets even though it was rainning heavily all day and i work outside...
Wyotech 05'-06'
Major= High Performance engine and custom chassis fabrication
1990 215k 760T
15G build in progress... http://www.forums.turbobricks.com/sh...89#post1722489
2001 1.8t Jetta
APR 93/100 oct. Chip ( 20 psi )
3" dp to stock exhaust
http://myspacetv.com/index.cfm?fusea...ideoid=1037037
http://myspacetv.com/index.cfm?fusea...deoid=18819786
WagenSport is offline   Reply With Quote
Old 05-15-2008, 12:04 AM   #27
WagenSport
WagenSport's Avatar
Old 05-16-2008, 06:12 PM   #28
WagenSport
WagenSport's Avatar
Did some intercooler fitment today. No more A/C. This is just the mock up. Tomorrow i have to do a little bit of cutting and fab work to get good fitment and attachment.
Old 05-18-2008, 11:55 AM   #29
WagenSport
WagenSport's Avatar
Intercooler is mounted and plumbed!!!
Old 05-18-2008, 11:51 PM   #30
WagenSport
WagenSport's Avatar
Got everything back together today! Still need to wire up my new themostatic fan controller though. Otherwise i got the compressor bypass valve block off plate made and installed, plumbed the radiator, modified the radiator brackets for its new slightly "forward" position, moved the manual boost controller MUCH closer to the waste gate, to lose tons of vaccum line in hopes of eliminating the crazy boost spikes i was having. Anyways, it is now 11:50 pm, charged the battery, turned the engine over and nothing. Checked for fueling, and i was getting none. I quickly found out while i was installing the fuel pump i had knocked the ground loose again. Fixed that, went for another try, still nothing. Thinking about it i forgot to check the position of the rotor button when i put the head together, so i think iam a good bit out of ignition timing. Tomorrow shall bring checking that and hopefully anything else that arises.
Old 06-02-2008, 12:52 AM   #31
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
Thumbs up
Very very beauteous, i still would like o port my own 8V or 16V...looks like you got rid of the lame A/C, that one extra bit off makes for ease of cool. and when it comes to replacing the turbo, no problem...great idea.
740tankDriver is offline   Reply With Quote
Old 06-03-2008, 12:00 PM   #32
DaButcher
Do a Burnout!
DaButcher's Avatar
Originally Posted by WagenSport View Post
Why must the AMM go before the turbo? Would i see any ill effects placing it after the turbo. It seems like some guys on the have been moving the amm to right before the throttle body, but i dont want to extend the wires. I got some play room with the AMM wires now after unsheathing them from the rubber insulators, but i just want to have the air metered correctly. So your saying i CANNOT do the setup with the blow off valve then the maf in that order after the turbo?
Hi, the AMM has a plastic housing.
It cant withstand pressure a lot.
You could fit the AMM inside a metal pipe, of course, but also the turbo might give off some oil, which might damage your AMM.
Also, I've heard that the AMM does not report properly while under pressure (not sure if this is true). It's easiest to just put the AMM on the "sucking side" of the turbo.
On my fathers 780, the dumpvalve is before the intercooler, after the turbo.
DaButcher is offline   Reply With Quote
Old 06-03-2008, 03:06 PM   #33
WagenSport
WagenSport's Avatar
Yeah, ive got it all together, put it on the intake side.
Old 06-03-2008, 03:34 PM   #34
shellshock
Below, is a photo of Clay
shellshock's Avatar
Looking nice man! I think you have the best wagon setup ever. Uber clean 760 dash, and hood that covers the cowl, IRS, and the good ole' redblock to top it off. No nasty whiteblock.
I have GOT to get some of those tails! My normal ones look fine, but the red and white just look sick!
Keep up the good work! She's gonna be sweeet
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 06-03-2008, 08:07 PM   #35
WagenSport
WagenSport's Avatar
Thank you! I really need some motivation to get outside soon and finish up retiming the thing. I agree i think its going to be sick once its done. It sorta sucks i wasnt able to get the 15g and injectors on yet but soon enough... after its running it will probably be within 2 weeks.
Old 06-05-2008, 08:59 AM   #36
DaButcher
Do a Burnout!
DaButcher's Avatar
do you have pics of the 15g rebuild? you have to reclock and make a wg bracket, right?
Old 06-06-2008, 05:25 PM   #37
WagenSport
WagenSport's Avatar
Sorry no photos, since i havent actually got the 15g yet. Should be an easy task one i actually have the turbo in my hands.
http://www.turbobricks.com/forums/sh...ad.php?t=55272
