Well:its already pretty damn stiff, to the point where i can deffinetly feel a bit of skittering through highspeed corners in the front
Having the maximum stiffness on your shocks can in theory do that to you if they’re too stiff for the setup.To add to that i have the koni single adjustable all 4 corners and righr bow my rebound damping is cranked to the max, how would adjustinf that help me
Try the softest setting then gradually work your way up from there to see how things feel. Or go to a middle setting.
Report back and let us know how it leaves ya.
Another note, what may be your main problem is 300lb fronts are not very stiff, really, especially if on Extreme performance tires and a low ride height. I’d think you want at least 400 or 450lb springs up front. The car will maybe even ride better if your real problem is running out of suspension travel for any reason(coil bind or bump stops, both of which will cause the complaint you have).
