They have a .530 knurl diameter. You can get longer studs, kinda tricky to find.
Front/Rear are the same? Any idea on where to find them? How did you find that knurl diamter?
So the stock length is the 1.5" ?
Wouldn't it be nice to have a FAQ section and/or a Vintage area?
Wouldn't it be nice to have a FAQ section and/or a Vintage area? Ah well.
I've been told 1.5 coils cut equals 2" Seems that is pretty much in the ballpark from other threads I've seen. We tried 1.5 coils (rear coils) but failed to get our before measurement.
We did have it aligned and I had the guy flip the lower BJ. Seemed to almost put it level.
Stock front springs still.
Do you have any rubbing? Did you have to trim any bump stops? Just trying to determine the threshold for modifications when lowering these cars.
Nothing on my drive home from work. (where it was aligned) bit less than 20 miles.
My kid hasn't mentioned anything.
Think I have a solution to the need for longer studs... Picked up some used "minilite" lug nuts that have a long shoulder that's threaded on the inside. The OD of that shoulder is just barely smaller then the ID of the bolt holes in my wheels. As long as the thread patterns are a match it should work perfectly!
How long of a stud would you need? There are some 4" ARP studs that have the correct knurl.
Alright, update!!!
So the Dodge turbine wheels I'm running have a much thicker mounting surface then the stock 122 steel wheels. This caused the lug nuts to only thread about 2-4 rotations. I believe 8 is recommended. So this is what it looked like:
[/URL][/IMG]
I was going to get some longer studs to fix the problem but quickly learned they would be hard to source and a bit pricey. Luckily I found some minilite lug nuts in the for sale section and decided to give them a shot since they had a longer shoulder.
Old vs. New:
[/URL][/IMG]
The OD of the minilite lug nuts was almost exactly the ID of the dodge wheel holes. They centered the wheel perfectly and I have about 15 threads engaged now. Looks alot better and makes me feel a lot better. Not to mention these we're way cheaper and easier then longer studs would have been.
After:
[/URL][/IMG]
Now I just need to find some nice centers for these wheels to cover the bearing caps/etc.
Minimum engagement should be about 1 diameter--or about 1/2"
As for a cover: clean everything up and paint the hub and nuts black...
It'll look great with white wheels.
