Old 07-31-2020, 10:16 PM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default A big valve 8valve is better than a 16valve head for 99% of tbricks
Change my mind.
Old 07-31-2020, 10:32 PM   #2
2turbotoys
Astro Zombie
2turbotoys's Avatar
No, you are correct. Especially if you port the crap out of it and gasket match.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-01-2020, 05:14 AM   #3
TurboDutch
Stainless steel exh valves are great!
TurboDutch is offline   Reply With Quote
Old 08-01-2020, 06:44 AM   #4
OttoB
My 531 is under construction. Only minor finishing on intake side and 38 exhaust valves. Good for 400 hp says the headmaster. Said also if using around 12 mm valve lift, 44 mm intake valves are fine.
Old 08-01-2020, 06:55 AM   #5
classicswede
Volvo upgrades
Why would you ruin the flow by gasket matching?
Old 08-01-2020, 06:57 AM   #6
classicswede
Volvo upgrades
Originally Posted by Marvelous3 View Post
Change my mind.
You are correct. I see a lot of abandoned 16v swaps. Had they stuck with 8v that would more than meet the power goals there is a good chance the build could have been completed
Old 08-01-2020, 10:52 AM   #7
shoestring
shoestring's Avatar
Wrong. A cylinder head with better flow characteristics is ALWAYS better. If you had said "A big valve 8valve is better than a 16valve head for 99% of TbrickERS", then I'd be forced to agree.
It's like saying you didn't want to date the super-hot, super-nice chick because she was too high maintenance. Maybe it was just maintenance you couldn't do.
Old 08-01-2020, 07:47 PM   #8
122power
dude
122power's Avatar
Hmmm isnt a bigger valve, ported 8v still cheaper than a 16v swap?
NA set up 16v all day, way more power under the curve.
Turbo Meh splitting hairs at that point. 16v make more but at what expense?
Now if the 8v was casted with a decent port shape, combustion shape, this would all change....
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 08-01-2020, 08:03 PM   #9
2turbotoys
Astro Zombie
2turbotoys's Avatar
Lol
Old 08-01-2020, 08:26 PM   #10
classicswede
Volvo upgrades
Originally Posted by shoestring View Post
Wrong.
Yes but she is known to often be a tease where the fat bird is know to always put out
Old 08-01-2020, 08:58 PM   #11
IansPlatinum
IansPlatinum's Avatar
I kinda wish I could make my valves smaller or add some sort of fins/grooves to them
So for me yeah I think 8V > big 8V > 16V
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 08-01-2020, 09:12 PM   #12
Fred Gwynne
Does gasket matching mean making sure the intake and exhaust gaskets have the same internal diameter of the valves?
Old 08-01-2020, 09:14 PM   #13
I think a well ported stock valve head would work for 95% of tbrickers.
Old 08-02-2020, 02:06 AM   #14
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
spend the money on a real turbocharger instead
One Volvo left.
1982 244ti (313chp), 2011 Audi S4 (333chp) , 2016 Kawasaki 650R (76chp)
DurableSwedish is offline   Reply With Quote
Old 08-02-2020, 02:38 AM   #15
Tsayloco
Tsayloco's Avatar
Certainly more than adequate for me, I also prefer the 8v sound. Call me a weirdo. IDK I'm not smart enough to argue the details. 16v does have its own inexplicable cool factor.
Tsayloco is offline   Reply With Quote
Old 08-02-2020, 04:31 AM   #16
mitch1971
A 16v can use shorter duration cams so will have better mid range power and still match a 8v top end power, that’s the advantage I think of a 16v engine over a 8v.
mitch1971 is offline   Reply With Quote
Old 08-02-2020, 05:25 AM   #17
classicswede
Volvo upgrades
No gasket matching is grinding the ports out so they are the same size as the gaskets. All it does is slow the gas speeds. The throat is not where there is any restriction in the head but around the valve stem is where the work is needed
Old 08-02-2020, 05:27 AM   #18
classicswede
Volvo upgrades
Originally Posted by mitch1971 View Post
A 16v can use shorter duration cams so will have better mid range power and still match a 8v top end power, thatís the advantage I think of a 16v engine over a 8v.
Yes that is the advantage but you do loose torque and engine braking with a 16v. David Vizard has come up with the polyquad head that increases swirl and tumble to improve torque. Never see it done with a Volvo head and how much gain you get is a ?????
Old 08-02-2020, 08:13 AM   #19
shoestring
shoestring's Avatar
Well played, sir.
Old 08-02-2020, 10:09 AM   #20
Marvelous3
Marvelous3's Avatar
Right. You wine and dine her. Treat her nice. Then take her home to find out the tits are fake and that big bush isnít the Brazilian that was advertised.
Old 08-02-2020, 02:10 PM   #21
shoestring
shoestring's Avatar
Damn! You guys gettin' nasty...
Old 08-02-2020, 02:50 PM   #22
TurboDutch
Actually turns out to has a huge big c*ck
Old 08-02-2020, 04:53 PM   #23
Well, I've been running a flowed 405 with stock valves for a long time. It revs easily to 7k or more if you wanted to and runs better from off idle to redline than when I ran the engine with a stock head.
I think the 405 with flow work or any stock 8v head with work would easily satisfy most power goals for a fun street car while keeping it 8v simple.
Old 08-02-2020, 06:23 PM   #24
Thekanezzi
Thekanezzi's Avatar
Are we talking pure performance or driveability as well?
At the same power level, wouldn't a 16v have better street manners than an 8v?
Thekanezzi is offline   Reply With Quote
Old 08-02-2020, 06:52 PM   #25
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
yeah pretty much. the issue is not so much one of head choice but relative tuning ability. it is not limited to 16v cars either lol.
a better way might be to say "you'll have best results when you do not exceed your abilities as a mechanic", but then if you never try new things you'll never learn anything either.
Megasquirt Tuning!
