Old 04-25-2020, 10:05 PM   #1
Jack
junkman
Jack's Avatar
Default b23 + side webers, what cam to use ?
got a high compression B23 bottom end
530 ported turbo head
pair of 45s webers
what cam should I be using
what I has at home but would get something else if needed
- ipd turbo cam
- M cam
- T
- B
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 04-25-2020, 10:11 PM   #2
'B'
Old 04-25-2020, 10:13 PM   #3
RvolvoR
Enem k13 and throw the Weberís in the garbage. Buy some jenvey itbs and donít look back.
Old 04-25-2020, 10:21 PM   #4
Jack
junkman
Jack's Avatar
ookay
Old 04-26-2020, 01:23 AM   #5
culberro
culberro's Avatar
What compression ratio? Like standard flat top b23?
Old 04-26-2020, 02:25 AM   #6
Jack
junkman
Jack's Avatar
yes
Old 04-26-2020, 06:58 AM   #7
classicswede
Volvo upgrades
Of the cams you have the B is nearest to a working cam. Of factory cams the H would be ok but there are many after market cams out there that would do more for you. What was the reason for little 45's?
Old 04-26-2020, 04:25 PM   #8
Jack
junkman
Jack's Avatar
like what
whats wrong with the 45s?
Old 04-26-2020, 04:42 PM   #9
classicswede
Volvo upgrades
they are a bit on the small side. 48's are a more common choice or 50's for a all out engine
Old 04-26-2020, 08:17 PM   #10
culberro
culberro's Avatar
45s should be fine with a 37-40mm choke, especially if you’re not going to be spinning to orbit.
Compression is kinda low for a super aggressive cam, but I agree with Ashers cam recommendation.
The Timo’s Motors 13.1 cam seems to be pretty solid as well.
https://www.timosmotor.com/kamaxlar
Old 04-27-2020, 01:02 PM   #11
You need a rubber cam. The faster it spins the higher the lift and duration.
I'd look for a V cam if you are wanting a factory cam. The K would be good as well.
Aftermarket there are lots of great choices. A V16 n/a from enem would be a good one.
Old 04-27-2020, 10:55 PM   #12
Leon_pp
aftermarket, something more than a stock cam
Leon_pp is offline   Reply With Quote
Old 05-01-2020, 02:12 AM   #13
klr142
Turbo, what?
klr142's Avatar
Like mentioned above, the B is the closest match for what you have. A larger cam would be better; but you’ll also want higher compression. The 45s are smaller for really good power, but with a B cam, a “ported 530”(by who; how good are they and it?), and stock compression(assuming stock headgasket and the head hasn’t been shaved any), it’s likely an ok match. Except you want more cam... You could maybe get between 120-140whp depending on everything. Maybe more with more compression and a larger camshaft.
Most importantly, is this a race car or street car? With the DCOEs, I take it no emissions testing will be required?
