Old 06-13-2020, 06:26 PM   #1
Benzine
Benzine's Avatar
Default Amazon engine swap
I've had a '67 Amazon since 2010 that I put hundreds of hours of welding into. It's now a rolling shell with new springs, dampers and a fully painted and protected undercarriage without an engine or transmission. So a solid blank canvas.
I've not touched it for years for lack of funds but my dad is interested. He's wanting to get rid of his Boxster (too low and manual) and is wanting to help out for us to finish the amazon and both use it. Ideal! An auto would be nice (it originally was an auto... B18 with a bw35 3 speed - both engine and trans are gone). He'd like to keep it a volvo engine. Not after daft power, something peppy would be good. So if we're going the auto route I'm guessing my options are:
  • b18/b20 with bw35
  • redblock with aw71
  • t4/t5 or n/a whiteblock with aw30-40
Any other volvo options and opinions on what's the best route? I'd have thought a red block with aw71 would be best cost wise and, from what I remember reading, could even link up to the existing dashboard auto shift. T5 is tempting but is it going to be a nightmare controlling the trans? Any thoughts on this welcome
Benzine is offline   Reply With Quote
Old 06-13-2020, 06:34 PM   #2
white855T
Redblock with aw71 is the best option. It will have the least amount of headaches. In the land of manuals, I don't know how much trouble it is to find an auto.
Old 06-13-2020, 06:38 PM   #3
Benzine
Benzine's Avatar
Thanks. It's easy enough to find an auto over here. Even a couple in the local scrap yard at the moment.
Old 06-13-2020, 06:43 PM   #4
grumpy dad
Hi
I am in England
have a amazon estate
i have fitted a 16 valve Volvo Penta 2.5 Lts its running twin su carbs 175 horses
nice easy fit
5 speed manule but you could use aw 71
PM me if you would like to come and have a play
or i can give you my phone number
grumpy dad is offline   Reply With Quote
Old 06-13-2020, 07:51 PM   #5
classicswede
Volvo upgrades
I would go redblock and AW70/71
To keep things simple I would keep it NA, possibly add some CC's rather than boost
Old 06-13-2020, 07:58 PM   #6
white855T
Originally Posted by grumpy dad View Post
Hi
I am in England
nice easy fit
Can you post some photos?
Old 06-14-2020, 03:31 AM   #7
mitch1971
Hi
I am in England
nice easy fit
That’s very interesting, where did you source a good engine from. Nice power for a Amazon.
mitch1971 is offline   Reply With Quote
Old 06-14-2020, 02:40 PM   #8
TurboDutch
B30 with aw71 would be cool!
TurboDutch is offline   Reply With Quote
Old 06-14-2020, 07:37 PM   #9
grumpy dad
Hi
yes will post some pics in a few days for you
engines well I have 3 blocks and 5 heads
2 sets of car cams and 4 sets of penta cams
if you buy a penta head the week spot is the exhaust valves
take them out and give them a good wack on the edge of the seat
a lot of mine have snapped where the stem is friction welded to the head
you could just put a penta head on a B230 block use a cosmic head gasket
and that stops the valves hitting the pistons
B30 i have a 164 the B30 is much longer and a lot heaver so you will get real bad under stear and it less power than the penta
Old 06-15-2020, 03:21 PM   #10
MikeJr.
Gloss Boss
MikeJr.'s Avatar
8v B21/23/230s fit really good in these cars at a slant. Stock intake and exhaust manifolds fit N/A or Turbo. M46/47 or AW70/71 would also fit with slight tunnel mods. You can even use the 740/940 rear mount distributer. Your best bet would be to find a cheap 740/940 turbo and swap everything over.
Old 06-15-2020, 04:15 PM   #11
grumpy dad
Hi
Very nice
Old 06-15-2020, 04:34 PM   #12
Benzine
Benzine's Avatar
Thanks for the info everyone. That looks great. What's clearance like between turbo and inner wing? My steering is on that side
Grumpy dad, thanks very much for the offer! Where abouts are you in England? I'm lincs/Notts/leics border
Old 06-15-2020, 07:15 PM   #13
Oerski
Oerski's Avatar
I second that. wanna see this penta 2.5 mounted.
Oerski is offline   Reply With Quote
Old 06-15-2020, 11:19 PM   #14
pat244ti
pat244ti's Avatar
Josh [Yoshifab] sells slant mounts for the vintage models to stick a OHC redblock engine into
Im going that route on my 1800ES
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 06-16-2020, 07:24 AM   #15
Sparkles
Not enough, I'm afraid. If you mount the block upright so the turbo clears the steering then there's not enough room for the later inlet manifold. I forget if the k jet swan neck maifold fits with the block upright.
Sparkles is offline   Reply With Quote
Old 06-16-2020, 08:38 AM   #16
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Left hand drive conversion? Seems like it'd be pretty easy to do in an Amazon.
Old 06-16-2020, 10:23 AM   #17
AndrewNance
Amateur hour!
AndrewNance's Avatar
B21 intake will fit and should work well with the steering on the right side. I fit one to mine and it only didn’t work because there wasn’t though space to fit an elbow into the throttle body because of the steering column.
