Old 06-25-2020, 04:58 AM   #1
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Default Wanted: B230F swaps in 140's
Its been a while i have been looking at 140's as i decided i hated them after having several. Gave my last 145 actually away to a friend, here lies the problem because i still maintain it.
The B20 is on its last legs and so is the gearbox (i have a good spare one). So i could just ignore it all and wait till it dies but after selling all my project i am now somehow googeling 140's with B230 swaps.
It seems that nowadays there are allot of bolt on things to simply this swap , i have limited time to fabric stuff myself so i would look into these things.
In my head its sounds pretty easy but im sure im am missing thing
Needs to be done:
- Buy engine mount brackets: https://yoshifab.com/store/vintage-t...apter-kit.html
- Swap on carbs manifold
- swap linkadge to cable on the accelartion paddle?
- Cut some hoses to make the radiator fit?
Maybe needs work:
- swap oilpan and pump (or not needed with yoshifab mounts?
- Can you use the headmount distributor?
Does not need work:
- M40 swaps over and no need to adjust driveshaft
- Exhaust swaps over i think
= Profit?
Anyway looking for some cool project (links) that have tackeld this on a budget, no turbo's or crazy stuff just a N/A swap that runs less noisy and broken then the B20 does now
760 Turbo '86|Volvo 360 cup|Volvo XC90 04|
My Seller Feedback
Old 06-25-2020, 05:10 AM   #2
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
A friend of mine installed a B23F/M46 combo from a 1983 242DL into his wife's old '72 145E many years ago. There should be some photos of the swap on the Brickboard Gallery page. You'll have to go back a few pages to early 2000, though, since that is when he did the swap. Since he decided to leave the engine tilted, he did some custom fabrication of the oil pan, extended the tube for the brake booster to clear the intake manifold, replaced the throttle controls with ones from a '74 model, so the 240 cable would work.
@john242ti on IG
Old 06-25-2020, 07:08 AM   #3
mitch1971
I’ve only ever done the one engine swap and that was a lot more work and hassle than I imagined, before the internet. :-)
Why are you doing it? To do the 145 or to convert 140s and sell on? If it was me I wouldn’t consider either, not your car and with COVID 19 going on classic car prices are dropping like a stone.
For the 145 just source another B20, drop it in and spend your time doing something else. A 145 doesn’t need a B230 unless you’re spending a shed load of time and money on the rest of it. A engine build is a much much easier job than a engine conversion.
mitch1971 is offline   Reply With Quote
Old 06-25-2020, 07:34 AM   #4
Mr.Borrie
Mr.Borrie's Avatar
Oh for the money this isnt the best thing to do for sure.
Purply hobby and i got a junk 740 in one of my garages with a B230F so why not XD
I must agree with you on the COVID 19 too and car value.
There is a reason i sold off almost everything i have, one to get some buffer and second i can buy something back in 1-2 years for half.
Old 06-25-2020, 02:47 PM   #5
TurboDutch
So will it be standing straight or under angle with the yoshifab mounts?
TurboDutch is offline   Reply With Quote
Old 06-25-2020, 02:53 PM   #6
pat244ti
pat244ti's Avatar
Originally Posted by Mr.Borrie View Post
Maybe needs work:
Does not need work:
= Profit?
You won't need to change the pump or pickup with the slant mounts.
Headmounted distributor would likely not fit a 140 with a fairly short enginebay.
The M40 won't swap over without a custom bellhousing - keep in mind you are putting the engine at a slant mount. An m40 never came in a slant mount and I am almost positive it will not bolt to a bellhousing for a slant mounted transmission. I would look for an M45 or M47.
Also, what year is the 140? You might need some transmission tunnel work but I am not 100% sure. If it's a later one, you should be ok.
I am just starting the swap on my 1800ES [b23f + m47]
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 06-26-2020, 02:14 AM   #7
John242Ti
John242Ti's Avatar
There were some M40/41 bellhousings for the later engines. They are as hard to find as the B18/20 M45/46/47 bellhousing, though. Personally, I'd just find another B20B with some SU carbs and chuck it in there.
Old 06-26-2020, 12:40 PM   #8
classicswede
Volvo upgrades
To me the B20 feels faster in them. Fitting a B230A years ago into a 145 was a wasted effort and I would never bother again. Turbo swap yes but for NA your money would be better spent building a B20
Old 06-26-2020, 12:43 PM   #9
Mr.Borrie
Mr.Borrie's Avatar
Maybe Same or little power improvement but way less noise right
Old 06-29-2020, 10:56 AM   #10
OttoB
Tony has pics. Only in Finnish though
http://www.lintsi.info/wx/volvo/142/...142_vaihe2.htm
Old 06-29-2020, 03:33 PM   #11
classicswede
Volvo upgrades
The mistake we made was using the dog dish flywheel. I am fairly sure had we used the flat flywheel the results would have been a bit better but I do prefer to have the original engine. Having a 60's engine that goes very well is more satisfying
Old 06-29-2020, 08:04 PM   #12
John242Ti
John242Ti's Avatar
Another option would be to install a B20E with a M41 and run it on MSnS... Would give fairly good mpg (or liters/100 km) with better runnability, but without completely changing the car...
Old 07-01-2020, 07:35 AM   #13
OttoB
The problem with B20 is that they are seldom in good shape. It is easier to find decent B230F which doesn't need renovation. And rebuilding B20 is surprisingly costly.
Old 07-01-2020, 09:47 AM   #14
Mr.Borrie
Mr.Borrie's Avatar
This was my inital trigger too, I don’t care about original anyway.
Plus I have a 740 (with aw71 though ) junker anyway
Old 07-01-2020, 05:25 PM   #15
TurboDutch
Doe mij die aw71 als je er vanaf wil?
Old 07-01-2020, 10:13 PM   #16
Mr.Borrie
Mr.Borrie's Avatar
Ga die AW niet gebruiken , kan weg hoor
Old 07-05-2020, 03:04 PM   #17
itb-volvo
http://forums.turbobricks.com/showthread.php?t=289332
I like the b230 in my 144. Only put it in because the b20 that came with it was toast and I had the drive train parts sitting around.
itb-volvo is offline   Reply With Quote
