Old 07-16-2020, 01:23 PM   #1
mschultz373
Default should i even use this head?
hi all, i am doing a head gasket replacement on a 940T with intentions to modestly increase it's power down the road. I got the head resurfaced flat, but there are still a couple corrosion spots present on the head:
DSC-0109
DSC-0110
DSC-0111
iwb dice
should I be concerned enough to just get a new head? the main corrosion point, under the thermostat housing (second pic), appears to be about 1mm deep or so. there are a couple other corrosion spots pictured in #3. this is my first head job so i am not well-versed in how to assess the quality of the head and determine if it is worth using or not. But i appreciate any thoughts. thanks.
mschultz373 is offline   Reply With Quote
Old 07-16-2020, 04:07 PM   #2
culberro
culberro's Avatar
It should be fine, but I'm on the other side of the computer. Where does the fire ring (steel ring) from the head gasket sit in relation to the worst corrosion? If they overlap... that's not going to be good.
Ladies and gentleman, this is why you should change your coolant.
Old 07-16-2020, 04:26 PM   #3
mschultz373
they do not overlap. sits about 1-2mm away. i'm gonna run it and pray!
yeah, the PO was definitely using straight water.... corrosion in the coolant passages. not even distilled water....
Old 07-16-2020, 04:56 PM   #4
Ursan
Bored Member
Ursan's Avatar
Last time I had a head surfaced, the shop filled in those imperfections before surfacing. See if your shop offers that.
how psi a stock can support?
So Im a racist big deal who cares. Deal with it.
I admit I'm stupid...
Old 07-16-2020, 05:15 PM   #5
I too have had a shop fix stuff like that. Up to and including welding the surface of the head. Then machining it flat to match the head. I had that done on a marine 531 head and he also rebuilt the no. 4 exhaust port.
Old 07-16-2020, 07:56 PM   #6
mschultz373
well, i threw it in today. i'll report back if my engine explodes.
Old 07-16-2020, 09:14 PM   #7
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Then you're just one step closer to an LS swap.
Doing the wrong thing the right way.
Originally Posted by redblockpowered View Post
Will you do $14.99 shipped?
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
fatcatbestcat is offline   Reply With Quote
Old 07-17-2020, 05:24 PM   #8
classicswede
Volvo upgrades
Would not worry in the slightest about those minor spots
