Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
On the S90 I have there are plastic rocker panel covers that extend the body to more flat sided look & protect side of car from mud/rocks,looks like a easy transfer from S90 to 940 anyone put the rocker covers from a S/V 90 to 940/740?
The original way of attaching those would require making several holes to the rocker panel. And the bottom edge clips block any debree coming out of the drain holes. Many have used double sided tape or glue on to the top edge and C-clips or screws on the bottom. Maybe one screw to the rear wheel arch to secure it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
