Old 10-18-2019, 06:59 PM   #1
122power
dude
122power's Avatar
Default Accessory bell chimes while driving and with turn signals
Have a 1988 240 that the acc bell chimes when im driving, intermittently chimes or most of the time. Also comes on with headlight switch when headlights are on. Also when i use the turn signals lol. Swapped another ign switch in but still does it. Seeing if anyone has had this issue before i go digging.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 10-18-2019, 08:22 PM   #2
tiredoldtommy
tiredoldtommy's Avatar
Grounds
When you're a tired old gimp²,
you get easy to please.
'03 C70 HPT drop top 95k (stylin cruiser)
'83 242 turbo, 305k (ridge runner)
'84 245 NA, 248k (hauler/tractor)
'66 New Yorker, 440 4bbl (needs a new home)
'84 244tic (project or parts? definitely parts)
tiredoldtommy is offline   Reply With Quote
Old 10-18-2019, 11:19 PM   #3
philski o'flood
philski o'flood's Avatar
snip the speaker wires off inside the relay
philski o'flood is offline   Reply With Quote
Old 10-19-2019, 12:40 PM   #4
bobxyz
bobxyz's Avatar
Do the fasten seatbelt lights (if not burnt out) turn on for a few seconds when the chime misbehaves?
Try spinning the chime fuse (#13?). I think the chime ground goes to the steering column and then to the tunnel - see the ground wire shown in this thread: http://forums.turbobricks.com/showthread.php?t=351711 If the ground seems good, try replacing the chime with a junkyard one (they're pricey new), or just unplug it.
Old 10-19-2019, 02:33 PM   #5
122power
dude
122power's Avatar
Hmm ok. It does have an aftermarket radio in it also.
Old 10-19-2019, 03:06 PM   #6
cleanflametrap
cleanflametrap's Avatar
If it is intermittent, try wiggling the key. When my daughter's chime started dinging (91 244) with the engine running, she told me she has to jiggle the ignition key and some accessory (can't remember which) starts working again, the OD-OFF light goes out, and the chime quits.
Here's the logic for the noisemaker if you're into tracing mysteries:
-Art
Old 10-19-2019, 09:58 PM   #7
nel621
Is your bulb out light on also? Check your taillight grounds and make sure the bulbs "match" side to side.
Old 10-19-2019, 10:02 PM   #8
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Another thing, does the time delay for the dome light work? If not, check the brake light fuse and the wiring to make sure that there's power going to the brake pedal switch. That is, if the 1988 cars are old enough to have it wired like a 1980-85 GL, GLT or Turbo, or GLE, etc...
@1982_volvo_242_turbo on IG
Old 10-20-2019, 10:09 AM   #9
dm245
I just went through something like this on my 960. the chime would go off at things like opening the glove box, any door, trunk, hood, lighted sun visor and other functions. At 1st I snipped the wires to the little speaker inside the relay.
The issue was fixed when I replaced the chime relay.
DAVE previous- 83-242 DL, 84-242t, 83-245t, 92-965, 94-965, 94-855, 95-945, 91-780, 98-V70XC, 95-964
present- 91-745, 96-964, 87-635CSi
dm245 is offline   Reply With Quote
Old 10-20-2019, 12:02 PM   #10
philski o'flood
check the door switch...
