Old 11-02-2019, 04:10 PM   #1
VolvoLatAm
Default Oil pan temperature gauge
Has anybody used a temp sender from the non turbo 240 oil pan like one of the non volvo ones manufactured by users here? Plastic washers only? Looking for some extra data from the engine
Old 11-02-2019, 04:38 PM   #2
There was a member here selling a oil drain plug with a temp sender in it. I think that was Redwood Chair.
https://forums.turbobricks.com/showthread.php?t=323283
Old 11-02-2019, 05:19 PM   #3
VolvoLatAm
Yup, I reached out to him to ask about it, not sure if he still sells them
Old 11-02-2019, 05:42 PM   #4
planetman
planetman's Avatar
I still have 1 of these.
http://forums.turbobricks.com/showthread.php?t=313830
Eric
Torrance, CA 90502
Old 11-02-2019, 05:50 PM   #5
VolvoLatAm
those ones are crazy expensive though...I get they are a rare genuine Volvo discontinued part
Old 11-02-2019, 06:00 PM   #6
planetman
planetman's Avatar
Old 11-03-2019, 10:37 PM   #7
SwedishKnievel
SwedishKnievel's Avatar
I made my own. Bought a couple of replacement drain plugs from RockAuto, drilled and tapped one, threaded in a temp sender and Bob's Your Uncle. Worked great.
SwedishKnievel is offline   Reply With Quote
Old 11-04-2019, 12:56 AM   #8
ermit71
ermit71's Avatar
If you can get a bung welded on to the lower part of the oil pan there is less likely hood of breaking the sender going over a speed bump depending on the splash shield you have.
Plus it may open options sensor wise for you
Feedback
ermit71 is offline   Reply With Quote
Old 11-04-2019, 02:31 PM   #9
SwedishKnievel
+1 on this. I have broken off the end of the sensor. I think putting the car on a trailer. That said, in my case, getting the oil pan off was more work than the value of a sensor. All that said, the next time the motor was out I did have a bung welded on to the pan.
Old 11-04-2019, 07:55 PM   #10
lummert
lummert's Avatar
I once watched a video on installing twin turbos at the rear of a Corvette. Turbo drains were pumped back to the oil pan. I long punch was used to punch a tapered hole in side of the oil pan. This tapered hole was then tapped for pipe threads and a fitting was installed.
Old 11-05-2019, 01:23 AM   #11
RickATL
in waaaay over my head
RickATL's Avatar
Any chance you could post a photo of that? I would like to see how that would look. What kind of materials, etc...
RickATL is offline   Reply With Quote
Old 11-07-2019, 03:38 PM   #12
SwedishKnievel
This is the welded oil temp sensor bung. I can get a picture of the drain plug hack this weekend. For the bung, I think I got it off of amazon. If you search "3/8 NPT steel weld bung" you will see a bunch for <$10.
Old 11-07-2019, 07:22 PM   #13
Ursan
Bored Member
Ursan's Avatar
If you have the factory oil cooler, you can get the banjo bolt sensor. I've been doing it for almost 10 years, works well and just might be more accurate.
http://forums.turbobricks.com/showthread.php?t=310195
how psi a stock can support?
Old 11-11-2019, 04:16 PM   #14
SwedishKnievel
Here is an oil drain plug modified to accommodate a temp sensor:
Old 11-12-2019, 01:16 AM   #15
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
If we're talking B21 or B23, just get a VW oil temp sender from a Cabriolet or Rabbit/Scirocco and thread it in place of the oil galley plug at the back of the head. Make sure you use a copper crush washer to seal things. Temperature is about 10 deg C warmer than it is in the pan, but it works well and avoids being damaged by road debris or wayward floor jacks.
Old 11-12-2019, 02:28 PM   #16
VolvoLatAm
It's a b23a, do you think this will still work? Also, I heard the copper ones are bad on the oil pan and the plastic washers are better...does this still apply here? Have a link to one?
Old 11-12-2019, 05:01 PM   #17
John242Ti
John242Ti's Avatar
Provided it's the original head on the block, yeah it'll work. Copper would be better.
Send a PM to swedishiron.com asking for a VW oil temp sender. He should have a few.
Old 11-12-2019, 06:00 PM   #18
VolvoLatAm
yup, original head. thanks!
Old 11-13-2019, 03:56 PM   #19
lummert
lummert's Avatar
If reused a copper oil pan drain plug seal many times with no issues.
Old 11-14-2019, 12:43 AM   #20
c1800
Especially reusable if you re-anneal it.
