Ok what am I doing wrong?? Efan going in 1993 240
Efan out of a 940T I believe. Bench tested and both high and low speed work
Volvo switch out of a 850 I believe
New temperature switch from NAPA(Fs150) threaded into the radiator.
High and low speed from volvo switch to temperature switch is there a high and low prong on the switch or are they interchangeable?)
Power from volvo switch to relay pin 87.
Relay pin 30 to inline 30a fuse, to positive battery terminal
Pin 85 to ground (efan also grounded)
Pin 86 to a switch
other terminal of switch to 12v power in car.
When I turn the car to power on (not running) and flip the switch, I can hear the relay click, but no fan.
I followed the diagram on The Ranger Station website: https://www.therangerstation.com/tech_library/volvo_electric_fan.shtml
am I supposed to ground the temperature switch somehow? If so how?
or bad volvo switch, idiot installer, a little of both?
Pin 86 to a switch
