Old 04-28-2020, 07:27 AM   #26
Alan29
Alan29's Avatar
Also did mine while engine was in car by simply following the directions as included by Josh. It's probably the only thing not leaking on this car.
Signature.
Old 04-28-2020, 08:39 AM   #27
crogthomas
crogthomas's Avatar
Originally Posted by 77volvo245 View Post
Try a measure the hole dia on the block. it should be one inch.
Are you sure?
I measured three B230FT blocks and got closer to 25.1mm (1" is 25.4mm) which is a significant enough difference for a press fit to fail.
Old 04-28-2020, 11:28 PM   #28
77volvo245
77volvo245's Avatar
Originally Posted by crogthomas View Post
Are you sure?
I guess I should of measured before posting. I was going off memory of the size of the hole. The hole is smaller than one inch on the block
STSmachining
Old 04-29-2020, 03:17 PM   #29
Stiggy Pop
Stiggy Pop's Avatar
I've drilled and tapped blocks in the car successfully, can't see how dropping in a slip fitting with some glue would be any kind of challenge.
'79 242
943 pickup
Old 04-29-2020, 03:46 PM   #30
noz-e8tr
noz-e8tr's Avatar
Thank for the replies guys. At this point my question is a moot point as my turbo took a crap. I’ll be removing everything that was kind of in the way regardless.
https://youtu.be/rF0xEKSC_XY
Berserker 242 Build Thread
This subculture is not conducive to meeting women let alone inspiring them to drive 30 year old, rectilinear, underpowered shit boxes.
Originally Posted by Walt Disney
"All our dreams can come true, if we have the courage to pursue them."
noz-e8tr is offline   Reply With Quote
