Old 10-29-2019, 08:30 PM   #3076
doucheNozzle
doucheNozzle's Avatar
yeah I didn't video that, it's messy and there's nothing special about it really.
What'd you end up putting in?
Are you going to build another half filled block too?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 10-29-2019, 09:10 PM   #3077
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
stock na pistons, hbeam rods. not filled, not shooting for y00ge power, going to try and work on the short time while getting the big engine and the other car ready. I had more than enough power to ET faster than I did, so that's going to be focus for the time being.
Megasquirt Tuning!
Old 11-01-2019, 10:46 AM   #3078
linuxman51
linuxman51's Avatar
Cams and fuel pump showed up last night, still waiting on a couple other odds and ends (well, sorta waiting, more on that in a minute). should still be good for install this weekend, unlikely to have an initial start though this weekend. I mean, maybe... but probably not.
Progress however waits for no parts, and such is the case the past couple of days in the shop.. started running the stuff for air weds night (and ran the wiring for the compressor and started running the piping), realized I was missing a few things and had bought the wrong things, fumed about that a little, ran by HD last night, returned the wrong things, picked up the right things, and have run 2 drops so far.. one by the dyno (air brake) and one by the middle bay door. I'm going to use what I've got for the time being and see where I want to run pipe to next.. I don't use air for a whole lot anymore, but the things you want it for you pretty much gotta have it.
Wired up the new compressor last night, it's quiet.. so nice. can't wait to finish things up this afternoon and pressure test it all tomorrow. Broke it in last night, 30 minutes run time with no load on it (i.e. no pressure build up), oil still looks good, I'll probably change that in a month or so (basically, after about 5-10 hours of use give or take).
Hopefully I'm done with 'big' purchases for the shop for a while.. it's nice to have the new stuff but it's blown the hell out of the shop's discretionary fund.
Old 11-01-2019, 11:53 AM   #3079
linuxman51
linuxman51's Avatar
Someone mentioned something the other day in passing that got the gears rolling (no puns intended or implied), while I'm thinking about it I'll list the "modz" for this particular iteration, as well as the cost if I have one available..
street ported 16v head -$? already had it. stock valves, so.. what's a 16v head sell for these days? 300?
b230f block, pistons
ebay Hbeam stock replacement rods (~$250 or so depending on where you get them and what bolts you use)
MLS hg - $106
arp head studs - $200 (already had these though. Would recommend with the mls gasket, otherwise elring hg and stock bolts and maybe don't lean on it as hard as me lol)
yoshifab 272 cams - $500
yoshifab CAS adapter - $200? (I don't remember anymore)
yoshifab timing belt tensioner setup - $200
yoshifab billet crank gear - $175iirc
custom intake & exhaust manifolds - $? no telling
Hx-52 - $175 (no rly)
ford modular springs from BTR - $100
tool steel retainers from PAC - $100 (or there abouts)
bosch 2200cc injectors - $270
this is just for the engine, everyone is going to have their own preferences when it comes to drivetrain, etc, so I'll leave that out.. the short of it is th400 tastefully modified and upgraded with the requisite adapters, welded diff, 3.54 final drive.
A few words on this, the whys and wherefors and "but you said in _______ thread that _________"...
-generally I do not recommend running an MLS gasket with stock pistons.. this is still the case. Why am I not? well, do as I say.. but really, I planned on using the head studs anyway and the stock headgasket didn't have issues on my other 16v setup (the 940's), it roached the #4 without issues, so I figured why not. TBH, the temptation was great to re-use the mls gasket from the gold car previously (I still have it), there was nothing wrong with it per-se, but.. it'd be a real pain in the ass to put it all together and then have to turn around and take it back apart due to being cheap. you may question the use of stock pistons, and that's fair, there was definitely some scope creep on this project (As I've found most to have lol)
-Billet crank gear. this has been a go-to for me for a while now. I've been fairly lucky with my 16v stuff in that I've never thrown a belt or broken a crank gear, so my valve bending escapades are fairly limited.. miss-timed the engine once really early on with adjustable cam gears.. put it back to straight up and drove it around for a little bit, everything sealed up fairly well (i.e. it didn't really hammer the valves). Threw a lash cap on the big engine once when I didn't have my launch limiter set low enough.. not sure that ever actually made contact, but I will say that upon disassembly after the block cracked, there were a coupe exhaust valves (including the one that got stuck partially open) that didn't quite seal up real well anymore, so who knows. I've talked to a couple people who've had issues with stock crank gears, my advice has been and will continue to be the same: ditch the stock gear ESP if you're going to be running an interference setup (be it 8v or 16v), really much past ~300-350hp the crank gear becomes a liability, and your margin of error can be reduced to zero. I have had folks disagree (or be unwilling to spend the money), obviously ymmv and what not, but in my opinion it's cheap insurance that you're not likely to lose or wear out across several engines.
-non stock ford springs: little bit extra to help with the added boost this setup will see can't hurt, esp with the cams. probably not required (I'd at least replace old springs with new springs), but a bit extra spring pressure normally doesn't hurt.
Other incidentals: steel dowel pins on the cams and aux shaft, you haven't lived until you've tried to troubleshoot a performance issue that you finally track down to timing drift and discover that the aux gear dowel pin sheared off and it's slowly slipping every time you wind the motor up. For the same reasons you don't want to shear a roll pin on a cam on a 16v setup, so yeah.
think that covers it. I explained why 2200cc injectors in an earlier post, and the new in-tank walbro will be an interesting test case. I'll set things up to leave space for a second pump if the need arises in the future.
Old 11-02-2019, 01:52 PM   #3080
linuxman51
linuxman51's Avatar
my weekends always seem to start out the same: one attempted step forward, trip and slide downhill backwards.
first pressure test of the shop air system revealed a small leak by the dyno (no biggie, this is not the fall I'm talking about lol), fixed that, went to move the v8 wagon.. predictably the battery was ded (well, ded-ish), jumped it off with the new 940...wait hold on, let me back up.. when I popped the hood, there was a rodent nest on top of the intake. horrors filled my mind while I went back to the shop to retrieve gloves to toss that crap out. No such horrors were revealed, however upon starting up a new problem had arisen: the cheap **** SS braided line that came with the fuel rail kit had finally given up the ghost and there was a steady spray going over the turbo side of the car from behind the intake manifold. No big deal, this had already happened once (And I thought I replaced both pieces but I guess not), I have the good stuff on the shelf and it's all of about 8 inches of hose going from the back of the rail to the pressure regulator.
Then a 45 minute fight started, and ended in frustration and no progress. I cleared my mind with a trip to the hardware store, and now have eaten lunch. Let's hope the afternoon goes better than the morning lol
Old 11-03-2019, 11:33 PM   #3081
linuxman51
linuxman51's Avatar
so the day started out more or less like this:
yesterday afternoon saw work on a number of fronts, but very little progress on the gold car. Last night after dinner was another story entirely.. cleaned and sealed the cam box up, dropped in the new lifters and cams, torqued everything down. there is a valve cover sitting on there, but it's mostly for moral support (and debris deflection during engine installation)
If you want to hear about almost burning the shop down with mark's wagon, that story will be in OT in the "what'd you do to your car today" thread.
I made a quick blockoff for the heater pipe, not going to plumb that in at all (may work in a coolant bleed from the back of the head where it would normally attach back up front, but we'll have to see on that). cleaned threads and installed new exhaust studs, also studded the bottom holes on the intake side. more on this later (if it in fact works the way I want it to).
hung the engine from the hoist, finished a few things up (err note to self, install last two oil pan bolts at rear of engine)
did the timing stuff and bolted on the mounts (that driver's side setup is kinda special. I'ma replace that before long. look it's the best I could do a decade ago with the tools I had, and it certainly hasn't gotten better with age), and then, fuggit, wing'd it on in'er.
upskirt view.
Still have to tigten all the trans bolts and install the flexplate hardware, and about a thousand other things, but the engine is in there. The weekend goals were loosely met, and as a bonus, other things got handled as well.
Old 11-03-2019, 11:34 PM   #3082
linuxman51
linuxman51's Avatar
oh and on a side note: the tripod I was using for filming fell off the bench saturday morning and broke. I gotta get on amazon and get another piece of chinesium headed this way.
Old 11-04-2019, 01:44 AM   #3083
justjim
justjim's Avatar
Hold up, I need a link to the fire story asap
Past: 1995 855. 1989 780. B230ft with T3, Megasquirt (thanks Kenny)
Current 1998 S70 T5 MANUAL (with a busted manual)
1996 Ford Bronco 4x4. 35" tires, 5" lift, much badassness
justjim is offline   Reply With Quote
Old 11-05-2019, 12:12 PM   #3084
linuxman51
linuxman51's Avatar
need two of the big ones, Harry
tool piles on the bench are growing, parts piles are shrinking, gettin' closer.
converter is bolted up, oil filters are plumbed up, all but one bolt on the trans/adapter are tight (can't quite reach that top one with the car up in the air).
test fitted the new injectors, had to move the mount point for the rail a little bit (from the top to the bottom of the bracket), but they fit well. pinched the damn o-rings like a noob, but other than that...
currently they're put back up, and the intake manifold is sitting in the washroom sink down at the house waiting a good scrub a dub dub.
I really should get a buffing wheel and polish that thing up a bit, it's taken a beating over the years.
Old 11-05-2019, 01:30 PM   #3085
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Nice log.
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 11-06-2019, 06:41 PM   #3086
linuxman51
linuxman51's Avatar
not exactly, but whatevs.
couple minor setbacks, all in scheduling.. got sick yesterday, so no work on my car or mark's wagon. hopefully going to be feeling well enough to go out there tonight and at least get a couple things done. cleaned the intake up, so that will probably go on the car. got a couple odds and ends in the mail, some for goldie, those may make it on the car as well. Still waiting on various other components, may do a sending unit shuffle again with the other wagon, it won't be needing it's fuel tank any time soon (but then, I'm still in need of a couple of odds and ends for the fuel system yet, so there is that). Need to touch base with greg and find out about the exhaust manifold situation.
bling bling, and what not.
Old 11-06-2019, 10:12 PM   #3087
vwbusman66
vwbusman66's Avatar
That was supposed to be a phallic joke.
Can't wait to see this thing rip.
Old 11-07-2019, 11:59 AM   #3088
linuxman51
linuxman51's Avatar
despite recovering from a stomach bug, I was still able to get some stuff done yesterday.
-fixed the fuel line on marks' wagon, replaced the blown up flex fuel sensor (lol. they don't like 12v on the ground side). hopefully it didn't smoke the input on the ms as well.
-modified the intake manifold gasket, copper coated that, set that down on the head (hence the reason for the 4 studs). hooked up wiring to the starter and CAS. forgot to connect the block ground, will get that later. same with coolant temp sensor. whoops. New injectors installed in rail, rail installed on cleaned-ish intake, intake installed on car.
according to usps, my fuel sending unit should arrive today (thanks again 2manyturbos!) I may go ahead and simple green the fuel tank and get that rinsed out and drying this evening while I work on modifiying the sender for the new 525 pump..and looking to see what it'll take to run two of em in there. I have some ideas, but mainly I want to see how it's gonna fit and how the ol baffling is going to hold up to this abuse.. doesn't do me much good if I can get the pumps in there and they suck the baffled area dry when the fuel level is lower. Hm. random musings. this will likely just be a bridge I cross when I reach it, trying not to manufacture too many problems for myself right now.
oh and my cool guy tuner vent filters there rotted out, need two more ebay $3 filters (I'm postulating here, but I imagine they're not very expensive)
Old 11-08-2019, 12:39 PM   #3089
linuxman51
linuxman51's Avatar
I've reached a weekend of "lul" in the project, there are things I can (and will) work on, but nothing really earth-shattering or time consuming. Also, the drag every 1/2 crank rotation is bothering me probably more than I should let it, but total reckless abandon is not the goal here either, so I'll probably waste a few hours, drop the subframe and oil pan, and make sure I didn't hamfist something in there.
on the flip side, I've tracked down my next fuel filter setup, the dw160 10 micron unit. 1000lph, -8 fittings. I'd been considering the OE bosch filter with requisite adapters and additional lines, but thought "wait, why would I add all that extra stuff to save a couple bucks with a somewhat unknown solution". not supremely cheap, but not terribly expensive either, given the relative costs involved. should have that next week early, same time roughly as the exhaust manifold will be finished.
also looking into making the jump to a 16v system, but that may come a little later. they say electronics work better with 16v (hotter spark, faster injector response time, fuel pumps work better, etc), so..
again, while I'm not dumping large money into the engine for this exercise, I am willing to splurge a bit on things I know will get carried forward to the wagon when it's ready.
Old 11-12-2019, 03:31 PM   #3090
linuxman51
linuxman51's Avatar
not a whole lot to talk about from this weekend, I didn't mess with the gold car much (read: at all), in a hold-and-wait state currently with several things, progress should kick back up this coming weekend, with some other odds and ends along the way.
rest of the fittings should be en route, fuel filter I think gets here today, I'll ping greg and check. He dropped off the exhaust manifold sunday, however apparently I didn't point out the other cracks, and they weren't as noticeable. No big deal though.
I am making alternate plans for the exhaust gasket situation... 2 different vendors, 2 months apart, neither seem to be able to lay hands on parts :-/
cleaned the fuel tank, looked at the baffling in side it beginning to have doubts about my sender plans, but I reckon we'll see. since it's not a road course car, it shouldn't be as big of a deal. Could maybe get a big block of tank foam to stuff in there. The wagon will likely get a fuel cell, so perhaps this is all a moot point, but I'm intrigued with thought exercises so here I am.
Did take some time to fix a couple small issues on the new wagon.. replaced the rotten old exhaust gaskets and plugs, runs much better now. Ordered an assortment of cheap amazon boost controllers to do a sort-of 'shootout' with it (and I've been meaning to get a dyno boost controller, as it's not uncommon for folks to show up with ****ty or incorrectly installed boost controllers and not be able to up the wick reliably). May end up doing a little side-series on bpu stuff with that car, to show what works well, that sort of thing.. if time allows it.
Few wiring changes need to be handled ahead of the first start (resistor pack bypassed is one), but I'm hoping to be close to or at that point by the end of this coming weekend.
Old 11-13-2019, 11:20 AM   #3091
linuxman51
linuxman51's Avatar
fuel filter is pretty swanky. no ragrets over my other plan, which was to use an OE filter as I'd done with the 940. too busy in the house to head out to the shop, so nothing really got done yesterday. will have time today, but not a whole lot to work on. May start mocking up the fuel system, get a head start on that.
Old 11-13-2019, 04:24 PM   #3092
Texas240
Prius Owner
Texas240's Avatar
what's this filter look like?
93 245 LS Engine Swap Project
Old 11-14-2019, 11:02 AM   #3093
linuxman51
linuxman51's Avatar
it looks like purty. I'll get a pic or you can check the fb post from teusday night.
last night I let greg test fit his volvo manifold, looks awesome, fits pretty good as well. Gapped and installed new plugs, replaced the breather filters. Was shocked to see how clean the breather tank was, no cleaning necessary, woohoo!
then I spent an hour and a half fumbling around with the ptfe stainless hose and fittings.. took a while to get a firm grasp on the process, once I got that part sorted, it wasn't so bad. Main line run from rail to the back, gotta make the jumper to the fpr, and then the return to the back. yay.
Old 11-14-2019, 11:37 AM   #3094
doucheNozzle
I haven’t used the socket less line but I like the ptfe stuff over the traditional braided lines
Old 11-14-2019, 12:48 PM   #3095
linuxman51
linuxman51's Avatar
the ptfe stuff is just about the only stuff I can find that seems to be really safe for ethanol. the pushloc stuff is great, but it all turned rock solid on the gold car, and the normal AN hose that I used also got hard and audibly cracked when I moved it around while taking it off the car.
Old 11-14-2019, 01:13 PM   #3096
I've been debating going back to ptfe fuel lines. The Aeroquip Starlite is getting really stiff after just 2 years, and that's just running pump gas.
Old 11-14-2019, 02:40 PM   #3097
MikeSr.
What, me worry?
MikeSr.'s Avatar
Maybe switch to hard lines? Those nylon repair lines are usable for the flexible sections.
I coulda had a V8!
Old 11-14-2019, 05:24 PM   #3098
linuxman51
linuxman51's Avatar
may do that on the wagon, we'll see. I like the idea of the lines having some give, but it's not like they flop around in free space that much during normal operation. gmail tells me that a number of things have shown up at the house, hopefully gonna be a busy weekend.
Old 11-14-2019, 05:45 PM   #3099
cosbySweater
cosbySweater's Avatar
I use pfte for the feed line and rubber pushloc for the return. Going to do pfte on the return soon I removed a section of the return hose and took it off the car a few months back and it kept its shape. I was scared to look at it the wrong way..... Rock freaking hard
1995 Porsche 993
2013 VW Passat TDI
Old 11-18-2019, 09:53 AM   #3100
linuxman51
linuxman51's Avatar
aiight. didn't quite get to the cranking up point, but dangerously close. It should run some night this week no problem. Short list of what's left
-connect wiring for fuel pump
-turbo & plumbing
-lower radiator hose, wp belt and coolant
-bypass injector resistors
-mount coils
-set t-belt tension
-procure battery
fuel system is all hooked up and pressure tested. fixed the leaks (I think, will double check the fittings at the tank itself, stuffed the intercooler and radiator back in (had to remember where I had the radiator mounted, it didn't want to play ball initially). Should be picking up the turbo manifold this afternoon. pics in a bit, gotta pull em over to pbase.
