Old 01-10-2020, 03:27 PM   #1
Nickagriffin
Nickagriffin's Avatar
Default Style 42's on a 240
Hey all,
I recently got a set of 17" BMW style 42's. They are the ET20 version. Does anyone know what kind of adapters I'll need for these? I know the bolt pattern obviously, but width? Are the bmw wheels hub centric?
1992 Volvo 244 +T
1989 Volvo 245
Nickagriffin is offline   Reply With Quote
Old 01-10-2020, 06:01 PM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
Here ya go.
https://forums.turbobricks.com/showthread.php?t=338190
Dave B
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, hydro clutch, 3.91 diff with unmodified G80.
Old 01-10-2020, 06:37 PM   #3
Originally Posted by dbarton View Post
Pfffft.
Old 01-10-2020, 06:41 PM   #4
5x108, 65.1mm hub bore -> 5x120, 74.1mm hub bore. You will want a 20mm spacer max. If you can get away with it, a 15mm adapter will make things easier to fit. You will have to relocate your rear axle and cut and roll your fender lips. If you want to lower the car, you will also have to massage your inner wheel well, about 5" above the fender line. moving the axle forward 3/4" helps a great deal with clearance.
Fronts should not give you problems.
Old 01-10-2020, 06:54 PM   #5
thelostartof
unbalanced chemical
thelostartof's Avatar
Why not just have them redrilled so they bolt up and do not require spacers?
thelostartof is offline   Reply With Quote
Old 01-10-2020, 07:06 PM   #6
Who likes sunk wheels? Nobody? That's what I thought.
Old 01-11-2020, 09:55 AM   #7
dbarton
Dejected by Volvo
dbarton's Avatar
Short answer: Yes.
Hub-centric is about the hubs (or hub adapters). A wheel will only be hub-centric if the hub fits well enough to center the wheel. If a custom adapter is sought, it would be best if it was hub-centric.
Old 01-11-2020, 01:53 PM   #8
122power
dude
122power's Avatar
15mm is the thinnest motorsports tech makes fyi.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 01-13-2020, 11:02 AM   #9
Nickagriffin
How would one go about relocating an axle? Is this a super involved process? If so, I might just sell the wheels and start over again.
Old 01-13-2020, 12:33 PM   #10
Probably easier to re-drill the wheels.
Old 01-13-2020, 01:20 PM   #11
Who likes a molested and bent shell with flush wheels? Nobody? That's what I thought.
Fixed.
Old 01-13-2020, 01:50 PM   #12
Fixed.
Your shell is molested and bent
Old 01-13-2020, 02:21 PM   #13
77volvo245
77volvo245's Avatar
because too many holes
STSmachining
Old 01-13-2020, 04:22 PM   #14
Yea but not on purpose, also your mother smokes Cuban cigars.
Old 01-13-2020, 06:52 PM   #15
My mother smokes those girly skinny long cigarettes, thankyouverymuch.
Old 01-13-2020, 10:45 PM   #16
Nickagriffin
Would adjustable torque rods make enough of a difference to fit the rears?
Old 01-13-2020, 10:59 PM   #17
No that will just screw up your pinion angles.
Old 01-13-2020, 11:44 PM   #18
Nickagriffin
Another guy fit these wheels without changing the rear axle location. Plus I'd only be running 215 wide tires. I don't see why a relocation would be necessary.
Old 01-13-2020, 11:54 PM   #19
2turbotoys
Salaminizer
2turbotoys's Avatar
Is the car lowered? If so you may need to bring the axle forward to center it. If not, you may still need to trim the fender lip, use the thinnest adapters possible. You will have a lot of room on the inside of the tire and none on the outside.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 01-14-2020, 12:02 AM   #20
Nickagriffin
Yeah it's lowered. Think I'm just gonna sell these and try to find something with a FWD type offset. This build is super budget so not trying to spend a bunch of money on suspension parts
Old 01-14-2020, 12:05 AM   #21
They don't fit unless you fill and drill.
Old 01-14-2020, 12:11 AM   #22
Nickagriffin
Do you always talk in riddles?
Old 01-14-2020, 01:08 AM   #23
Always best to confuse them with the facts.
Old 01-14-2020, 01:57 AM   #24
LC4CARL
Aero challenged
LC4CARL's Avatar
@PDXvolvo on IG
Old 01-15-2020, 12:05 AM   #25
2turbotoys
Salaminizer
2turbotoys's Avatar
It is definitely easier to fit FWD wheels, and there is a huge amount of selection in the aftermarket. I tend to aim at an offset of 0 when using spacers, FWD wheels and wide tires, never get there but can get quite close.
