Old 02-07-2020, 10:37 AM   #26
Matilda Car
Another update:
Got the smoke machine hooked up and there were only 2 very tiny leaks. One pre turbo and one at the actuator. I will have to keep an eye on that one, going to have to dig out a spare and see if I can get rid of that leak, tiny though it was.
My local mechanic is the only one who will even think about touching my car. Some stuff I just can’t do mostly because I need a hoist or a certain tool, unfortunately I don’t live in an area where I can rent time on a hoist. He told me I am the only person who has ever asked him to hook up the smoke machine just because.
Dude also tells me that his guys are like deer in the headlights with my car and because they can’t hook up a computer to it they are unable to diagnose the car at all so he works on it instead. The fact that it is a hybrid system totally defeats them. But it is such a simple system - they can’t even troubleshoot? Nope. So he’s been having me come in from time to time to teach them about the car, it’s systems, and how to troubleshoot it. Holy crap!
Matilda Car is offline   Reply With Quote
Old 02-07-2020, 11:17 AM   #27
cosbySweater
cosbySweater's Avatar
Have you tried disconnecting the Watergate hose and taking it for a quick rip
1995 Porsche 993
2013 VW Passat TDI
Old 02-07-2020, 02:01 PM   #28
Dicktater
Cretin
Dicktater's Avatar
His turbo will get impeached if he does that....
**** off loser. I will **** you up. I back up the **** I talk. I don't back down because I am not wrong. You want some? Bring it mother****er.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 02-07-2020, 02:50 PM   #29
Lets see which wastegate actuator you used and how you mounted it.
Old 02-07-2020, 06:45 PM   #30
cosbySweater
Originally Posted by dicktater View Post
his turbo will get impeached if he does that....:-p
whoops
Old 02-07-2020, 09:46 PM   #31
Matilda Car
No I havenít disconnected it, why would I want to be doing that?
Old 02-07-2020, 09:48 PM   #32
Matilda Car
T3 actuator, I will put up some pictures up later when I get home. Cheers
Old 02-08-2020, 02:45 AM   #33
cosbySweater
See if it's still lazy. If it is you have a wastegate sealing issue. Also have you checked the timing belt?
Old 02-08-2020, 10:57 AM   #34
Matilda Car
I get what you are saying now, would more preload help there maybe? Belt is good, timing good. Hoping to add a bit of preload this weekend as suggested earlier and a MBC even if I donít increase boost pressure as suggested by gsellster.
Old 02-08-2020, 02:55 PM   #35
gsellstr
Vintage anti-ricer
gsellstr's Avatar
More preload really isn't needed on those actuators unless you are using the actuator to increase your boost pressure. I'm running 1.5 turns of preload on the actuator, holds just fine to 24psi, with an MBC to dial in the boost. Granted I'm using a Forge actuator now, but even on the stock Garrett T3 actuator I was sitting at a solid 18-19psi with an MBC on an 8psi actuator, with just the normal preload.
The Garrett actuators have a lot more spring pressure to hold the gate closed than the Mitsu actuators, so they don't require as much preload.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-08-2020, 09:35 PM   #36
Matilda Car
I had got the Garrett one because I thought it to be a better actuator so thanks for the info. I was going to try more preload just to see if it resulted in anything. I will definitely be adding an MBC. Might end up going to a lower psi actuator and MBC once summer hits. Removing the vented cap made a big difference.
