Old 01-02-2019, 12:38 AM   #1
940 16 valve
940 16 valve's Avatar
Default T5 to T5 pilot bearing
Just ordered an adapter plate from Roger Dee. In reading through the forums, I can't seem to find a definitive answer to what others have found that works.
While on the topic of the swap, what have folks used for slave/throw out bearing setup?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
Old 01-02-2019, 07:52 AM   #2
DET17
Reformed SAABaholic
Have you checked the whiteblock conversion thread? OldVolvo just updated with all the various TB addicts who have whiteblocked..... several are running the FORD T5 behind them.
Old 01-02-2019, 02:46 PM   #3
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Ping stick70. He’s the only one of us so far with an actual running t5/t5. Mines in body shop purgatory ��
Old 03-29-2020, 05:13 PM   #4
James M
Bored member
James M's Avatar
Anyone figure this out? Rough measurements from a broken caliper give me 35mm OD and 18mm ID being the right size. (N crank, 5.0 input shaft)
Old 03-29-2020, 05:28 PM   #5
Dirty Rick
Dirty Rick's Avatar
I'd buy a needle bearing for a 5.0 then machine a whiteblock pilot to fit the 5.0 bearing?
or make a sleeve to hold the bearing with a .0015 press fit for the bearing and the crank.
Old 03-29-2020, 08:27 PM   #6
oldschoolvolvo
oldschoolvolvo's Avatar
Apparently there are two different styles...one a bearing and one a bushing. I don't know the changeover years, but here is what I found from other TB'ers.
Originally Posted by stick70
The end of the crank is different. You will not be able to use the pilot bearing that the early 850 engines, and alex butchka specifies in one of the threads. I used an oilite bushing I found at Advance Auto Parts, they had it on the shelf. The part # is: Dorman brand, #14647. It's a little long, but I didn't bother cutting it down. NOTE only the the OD is correct! It will press clean into the crank, mine was a .002" press I believe. BUT the ID is too small! You will have to take this to a machine shop and get it reamed out.
https://forums.tbforums.com/showpost...7&postcount=91
Originally Posted by Alex Buchka
Here's a nugget for all interested parties:
Today I picked up a pilot bearing that will work with a T5 tranny on a whiteblock. The bearing requires a 17mm ID for the T5 input shaft, 35mm OD and 10mm width to fit in the whiteblock crank. A local industrial supply shop deals in NTN brand stuff and they happened to have the exact size I needed for $17 or so.
The bearing is NTN part number 6003LLBC3/1K, here's the white paper for it:
http://www.ntnamerica.com/datasheet....CATEGORY=RBSRD
It was a very snug fit in the crank just as it should be and the stock retainer circlip fit perfectly.
http://forums.turbobricks.com/showpo...6&postcount=76
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 03-29-2020, 09:31 PM   #7
James M
Bored member
James M's Avatar
I've heard two different crank sizes, good thing mine is 35mm
6003LLBC3/1K Seems to be what I'm looking for, thanks. Now to bang my head against the wall because my block is missing mounting bosses.
Old 04-02-2020, 03:59 PM   #8
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
NTN 6003 LLB C3 EM Radial/Deep Groove Ball Bearing
https://www.ebay.com/itm/NTN-6003-LL...53.m1438.l2649
*Not tested, but this what I picked up information wise from another user on here. See above.
.... I'm bored, I'm buying it now. Give me a weekish to test.
2010 Porsche Cayenne S - My ride - 99k stock
2010 Cadillac Escalade ESV - Wifeys ride - 205k stock
2007 Audi A4 3.2 M6 - daughters ride - 166k stock
2006 Volvo XC70 Wagon - sons ride - 175k stock
1992 Volvo 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress.
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 04-04-2020, 12:54 AM   #9
James M
Bored member
James M's Avatar
Installed the same one today and fits both input shaft and crank great, 1K vs EM is just the bearing prelube according to the manufacturer
Old 04-06-2020, 09:50 AM   #10
stick70
All the gauges
stick70's Avatar
Fwiw pay attention to the fit of the deeworks adapter to the bell housing. I ended up using a waterjet one I got from another member on here because the deeworks one was going to be a press fit into my bell housing. Not sure if that's as designed, but it's what I ran into.
Old 04-07-2020, 03:40 PM   #11
James M
Bored member
James M's Avatar
Didn't cause any issues with the bell housing but was a fraction too thin, input shaft was jammed into the rear of the crank and had to be trimmed a MM
Old 04-11-2020, 01:53 AM   #12
Smorgesborg
Smorgesborg is offline   Reply With Quote
Old 04-16-2020, 09:30 AM   #13
940 16 valve
Good to know! Are we talking a literal mm that you had to trim it?
Old 04-17-2020, 12:41 AM   #14
James M
Bored member
James M's Avatar
Not a full mm, just a little bit with a sanding wheel. Might be because it was a ebay input shaft to replace the SN95 one and who knows there tolerances. Just try to turn the engine over once it's all bolted up and if it isn't binding you probably wont have to touch it
Old 04-22-2020, 10:24 AM   #15
stick70
All the gauges
stick70's Avatar
I had this same issue iirc
Old 04-29-2020, 09:48 PM   #16
940 16 valve
Dealt with it today. Ended up having to take off 0.25" off the input shaft for clearance - for future reference
Old 04-29-2020, 11:08 PM   #17
James M
Bored member
James M's Avatar
Seems to be a little more common then one would hope.
