Old 08-05-2020, 10:47 AM   #1
IansPlatinum
IansPlatinum's Avatar
Default Correct Anti-seize for stainless Exhaust manifold studs
I am having trouble finding my answer on here or the rest of the internet.
Folks, those who have installed stainless exhaust manifold studs, what anti-seize did you use on the stud going into the head?
I have Permatex "aluminum" (silver color, supposedly contains aluminum, graphite & maybe copper?) anti seize on hand.
Should I be using something different, or just send it with the aluminum stuff?
EDIT: please move, accidentally posted to wrong subforum
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 08-05-2020, 11:01 AM   #2
woodenpudden
lacks goats
woodenpudden's Avatar
Any is better than none, but copper anti-seize can withstand slightly higher temperatures.
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 08-05-2020, 11:14 AM   #3
The solid copper or solid graphite paste is what you want.
The gray is just for getting all over your clothes and tools.
Old 08-05-2020, 11:25 AM   #4
Stiggy Pop
Stiggy Pop's Avatar
I use copper on really hot stuff.
'79 242
943 pickup
Old 08-05-2020, 11:39 AM   #5
PCH
Nickel anti-seize is for high temp applications.
Old 08-05-2020, 12:36 PM   #6
IansPlatinum
I read that that's the good stuff. They don't have it in any stores nearby though. Maybe I can order on amazon.
I'll probably also go see if autozone has some copper antiseize
Old 08-05-2020, 12:53 PM   #7
carver
Redblock for life.
carver's Avatar
I'd go for Loctite 77124 with stainless especially with the aluminum head.
Old 08-05-2020, 12:56 PM   #8
142 guy
If you go to the Permatex website
https://www.permatex.com/product-cat...ts-anti-seize/
and click on the particular product, you will see a tech documents tab. Open the TDS document and it will provide you with application information including temperature ratings. Permatex's application info for the nickel version suggest use primarily on exhaust stuff.
Old 08-05-2020, 01:17 PM   #9
kyote
Living The Dream
kyote's Avatar
I'd suggest copper anti seize, but I would not suggest stainless exhaust hardware.
Maybe if we lived in Michigan, but here in TX I'm thinking the risk vs reward isn't there.
Old 08-05-2020, 02:56 PM   #10
PCH
I believe I bought mine from Autozone and they had it on the shelf. You can ask if they can get it from warehouse.
Old 08-05-2020, 03:35 PM   #11
IansPlatinum
I already removed the originals, and the stainless replacements are already here
The nuts are the copper ones FCP sells. aluminum & stainless corrode, but not in a catastrophic way. We do 1000hr salt fog testing on stuff at my work, frequently containing junctions of aluminum & stainless (5052 & 316 specifically). I don't think it has ever caused an issue in our application, which is sensitive RF equipment & will detect if advanced corrosion is present because it'll induce PIM.
And maybe this is one of those experience things where you'll end up being right, but I think the consequence of failure in this scenario is low.
Also the car doesn't just drive in TX
Old 08-05-2020, 03:36 PM   #12
IansPlatinum
Amazon's got this on prime 1-day shipping, so I think that's gonna be the way to go
Old 08-05-2020, 03:50 PM   #13
tjanson
tjanson's Avatar
What's the right way to install studs, anyhow? Is there a way to keep them from backing out when you loosen the locking nuts?
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 08-05-2020, 03:52 PM   #14
IansPlatinum
Hmm, now I'm curious, has anybody used this stuff before?
https://www.amazon.com/dp/B001HW82SW..._8UWkFbW5CSX7K
High temp and non-metallic. Might have to give this one a shot.
Old 08-05-2020, 03:58 PM   #15
The stud coming out with the nut is from corrosion. The stud gets torqued to a spec if you are being careful. Tight enough to stay in there but not so tight it's jammed in the threads. Probably something low like 10-15ftlb as a guess. The anti seize being on there tends to make you over torque things so be careful.
I use the Wurth copper anti seize. Great stuff and the can has lasted about 20 years. The aluminum anti seize is good to low temp applications such as shock and suspension bolts.
Old 08-05-2020, 03:59 PM   #16
IansPlatinum
I think if it backs out when trying to loosen the nut, it's no biggie
Just remove nut & reinstall stud. I think the two reasons for being a stud for this application are
1: hanging of manifold & gaskets
2: greater chance of removal. if it's a screw, you must loosen the junction at the aluminum head & fastener. If it's a stud, there's two chance that it'll come off without stripping or snapping
and the stud has an unthreaded section mid-way that starts to snug up on the surface of the head. I think that's how contact pressure is achieved in the stud.
I just measured my old OE volvo stud and the unthreaded portion is 7.95mm OD, threaded is 7.83mm. So I wouldn't really bank on its presence having to do with anything related to diameter.
Old 08-05-2020, 07:14 PM   #17
c1800
Nickel, FTW.
Old 08-05-2020, 07:47 PM   #18
c1800
Thats a 1oz Tube.
Old 08-05-2020, 08:08 PM   #19
lummert
lummert's Avatar
I've read about using Maalox to prevent galling of stainless bolt threads.
Old 08-05-2020, 08:44 PM   #20
Stiggy Pop
Stiggy Pop's Avatar
Bottom out the stud then back it out a 1/4 turn. High temp anti-seize and new nuts every time. Always works for me.
I prefer the OE volvo studs over stainless for the exhaust side.
Old 08-05-2020, 09:03 PM   #21
2turbotoys
Astro Zombie
2turbotoys's Avatar
I always prefer the "aluminum", the copper always turns gummy and weird on plugs and exhaust stuff. It's rated for 1600 degrees vs 1800 for the copper.
https://www.permatex.com/products/lu.../?locale=en_us
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-06-2020, 02:18 AM   #22
Sparkles
If you're using two nuts tightened together, put a spanner on each one.
Sparkles is offline   Reply With Quote
Old 08-06-2020, 03:42 AM   #23
Kjets On a Plane
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 08-06-2020, 12:17 PM   #24
Stiggy Pop
Stiggy Pop's Avatar
^ good addition, I also use the OE Volvo cupped turbo washers.
Old 08-06-2020, 05:27 PM   #25
tjanson
tjanson's Avatar
Don't know if you can get the nice OE radial/toothy knurl pattern nuts for the n/a manifold to downpipe anymore. Allows a socket to fit well for easy removal, functions like a more primitive nord-lock washer in a hot spot.
Nothing else has worked quite as nicely in that spot.
Good luck.
Pegasus sells locking Metric "jet nuts" with a reduced hex that might work nicely on a NA downpipe. I haven't had any issues with non-locking nuts on those studs, though, I just tighten them "FT" and they stay tight.
https://www.pegasusautoracing.com/pr...p?Product=MJET
