Old 09-16-2020, 04:25 PM   #126
940 16 valve
940 16 valve's Avatar
Nice to see the car is getting some proper use! Who's E36 M3 convertible? Very nice.
How did you end up getting your tach going btw, did you use the M4.4 tach output?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
Old 09-17-2020, 04:08 AM   #127
James M
Bored member
James M's Avatar
My brother picked it up a few days before that post, super clean and for a steal of a deal.
Yep just m4.4 tach output from b21
Old 09-17-2020, 10:17 AM   #128
940 16 valve
Nicely done. I picked one up about a decade ago and they're a blast!
So you just hooked up b21 to the stock tach and it worked? That seems too simple. Did you manage to get the car to boost past WG setting?
Old 09-17-2020, 11:25 AM   #129
James M
Bored member
James M's Avatar
Seems too simple but it works. Haven't been past ~8psi since I've got the stock NA 240 fuel pump still, need to install the DW300 I picked up. I've messed a little with the TCV but I don't know off hand if it's working, might remove it and see what wastegate pressure is alone and it the valve is working.
Old 09-17-2020, 05:18 PM   #130
940 16 valve
Does seem too simple! Good call on the DW300, thats what I went with too. Had a walbro in the old 940 and the DW is a bit quieter despite pumping more fuel. I guess we'll know more if I also don't have more than base boost when I get to it, maybe the speed signal is needed!
Old 09-17-2020, 06:01 PM   #131
James M
Bored member
James M's Avatar
I was emailing Aaron at vast tuning and he said there was not a speed limitation on TCV duty cycle, but I was also reading about gear limitations (so you don't have tons of wheel spin and boost in first gear) but you can remove that in tunerpro. I have from my .bin but I have no idea if it worked
Old 09-17-2020, 09:53 PM   #132
James M
Bored member
James M's Avatar
Wastegate pressure is indeed 8psi on my 15g
20200917-175616
Went threw my wiring and it's good according to a 96 850 motornic 4.3 diagram and 98 v70 motronic 4.4. last time I was using the digital dash function in tunerpro I was seeing TCV duty cycle numbers, I'll have to find my cable again and take another run and see what it's at.
My assumption is that if I'm getting a duty cycle output in turbopro then the ECU isn't limiting boost by speed or gear, sound like a solid assumption?
Old 09-17-2020, 11:18 PM   #133
2turbotoys
Astro Zombie
2turbotoys's Avatar
I ran my 15g at 22 psi on LH2.4 with no problems (and certainly didn't use a TCV, used the old school Dawes device style boost controller), I don't understand the last sentence. Crank the wastegate rod a bit and use a simpler boost controller, unless you are concerned about the transmission.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 09-18-2020, 02:47 AM   #134
James M
Bored member
James M's Avatar
Sorry the last sentence was worded strangely. I'm saying if the ECU is outputting a duty cycle signal to the TCV then I'm not having any issues with a speed or gear boost limitation because of missing signals to the ECU.
I've got a spare MBC I may install but would like to get the TCV setup working. High boost at low RPM seems to be a killer of these motors and when upgrading to a larger turbo I don't want to have to pick between setting the boost low enough to not bend rods at lower RPM or being light on the throttle until it revs up a bit.
Once I get the fuel pump in I'll probably throw on the MBC while I try to figure out the solenoid, but it seems like most over at volvospeed tune with the TCV to avoid damage and have more control of boost in specific situations.
