Old 03-04-2015, 04:15 AM   #1
polaris
Mk V
polaris's Avatar
Default M46 Shifter Set Screw Alternative
The LeMons team I am on has been getting ready for the upcoming Sears point race. We had to install a new engine after we lost a valve spring which dropped a valve which grenaded the engine. A new B230 has been finished being installed, but the set screw at the bottom of the M46 has gone missing in the last couple of weeks.
Does anyone know what the size/thread pitch this is so we can source a replacements. From some searching looks like the Volvo part number is 3270193 but its listed at NLA status.
#38 in this parts diagram
polaris is offline   Reply With Quote
Old 03-04-2015, 12:48 PM   #2
The Librarian
Where did you get that part number? I came up with 1220802 and it's still available.
http://www.volvopartswebstore.com/sh...=0&modelYear=0
Old 03-04-2015, 01:02 PM   #3
Probably 6x1M try a bolt in there, and hit the hardware store.
Old 03-04-2015, 01:23 PM   #4
Jack
junkman
Jack's Avatar
i have one free
I love you even more Jack.
Old 03-04-2015, 01:30 PM   #5
Kestrel
Kestrel's Avatar
I hit up the hardware store for my last one.
Be careful... You *must* pick the right length set screw. If it is too long, and the hex portion sits outside the threaded hole of the bottom of the shifter shaft, you're liable to crack the screw when you tighten it down or try to remove it next time. And when that happens, the nightmare starts. (Trust me on that one )
Old 03-04-2015, 02:12 PM   #6
Hoggster
Hoggster's Avatar
I chucked out #9 and #38 and used a bolt/nut/washers that fits in its place. No more worries about stripping a crappy little grub screw and you can get to it with the guibo still in place.
Hoggster is offline   Reply With Quote
Old 03-04-2015, 06:00 PM   #7
coonmanx
Nobody said just grab the set screw from a junkyard?
Jim C.
Don't own a Brick anymore. It got crushed.
coonmanx is offline   Reply With Quote
Old 03-05-2015, 04:30 AM   #8
polaris
Mk V
polaris's Avatar
Appreciate the responses back on this question. A big thanks to Jack for offering up a replacement up as well.
Old 03-05-2015, 01:39 PM   #9
MistrThou
Masked Moogle
MistrThou's Avatar
I just drilled and retapped it to something available at Ace Hardware. Twas a fairly soft and easy drill/tap.
Originally Posted by Old Guru
Current cars: Something old, something new, something borrowed, something Maroon.
MistrThou is offline   Reply With Quote
Old 11-05-2019, 08:55 PM   #10
I Am A Bicycle
Hey dude what size was the screw you used for #38? Any tips on the length of the screw or replacement and whatnot?
Thank you!
I'm gonna get this from ipd or stay https://www.stsmachininginc.com/coll...-240-740-volvo
I Am A Bicycle is offline   Reply With Quote
Old 11-07-2019, 03:29 PM   #11
77volvo245
77volvo245's Avatar
Thank you!
m6x1 its not a hard part to find.
https://www.mcmaster.com/set-screws
STSmachining
