Old 02-08-2017, 10:03 PM   #1
73amc
Default Qa1 Probably Kit
Has anyone ever installed a kit such as this one on a 240? https://m.summitracing.com/parts/qa1...FY61wAodsUUGng
I'm looking to do something like this in spring or summer.
73amc is offline   Reply With Quote
Old 02-09-2017, 12:31 AM   #2
Mueller
Mueller's Avatar
Looks similar to what Jeff did to his turbo'd LS powered 242, 55Superbeetle(?)
Old 02-09-2017, 12:59 AM   #3
cwdodson88
That's what I'm going to do with my 8.8 swap into my 122. Saw a pickup without a bed that had done the same thing with and he said it was all really straight forward.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-09-2017, 06:00 PM   #4
73amc
I guess I need to figure out what length I need
Old 02-18-2017, 11:57 PM   #5
73amc
Does anyone know what 55superbeetle used? Was his all custom parts or was there commercial parts available?
Old 02-19-2017, 12:12 AM   #6
If you leep the motion ratio you will want a set with a spring rate of 42% of your front end.
Collapsed length of 11.7" will not allow you to go very low at all with the stock lower perch location.
Old 02-19-2017, 12:30 AM   #7
centason
Autogestion
centason's Avatar
Just ask 55superbeetle.
Member: TBCCS
"Those who do not move, do not notice their chains." -Rosa Luxemburg
Old 02-19-2017, 12:40 AM   #8
55superbeetle
My shocks were double adjustable QA1's, lower control arm mounts and shock mounts were just a carved out of some rectangle tube. Control arms were cheap swaged rods with economy QA1 heims. Think I only had a few hundred bucks in the whole setup but I got shocks and springs used on ebay. I have used that kit on other cars though and don't see why it couldn't be used on a 240, tons of adjustment in that kit but the best thing to do is set your ride height and measure before ordering anything.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 02-19-2017, 12:54 AM   #9
55superbeetle
Making the control arm mounts adjustable will allow you to move the instant center around and change the way the car reacts to power.
Old 02-19-2017, 12:59 AM   #10
73amc
Ok. I figure I'll get the car in the air and adjust the rear height with a floor jack and take some measurments. Where did you source your rods? Local?
Old 02-19-2017, 01:00 AM   #11
55superbeetle
http://www.speedwaymotors.com/
Old 02-19-2017, 01:00 AM   #12
73amc
I'd love to get my hands on some of the control arm mounts. They look great.
Old 02-19-2017, 01:48 AM   #13
73amc
Do you recall the length of your coil overs
Old 02-19-2017, 04:14 AM   #14
55superbeetle
Sorry I don't
Old 02-19-2017, 12:28 PM   #15
55superbeetle
I think you could adapt these pretty easily.
http://trzmotorsports.com/wp2/?produ...l-arm-mounts-2
http://www.racecraft.com/index.php?m...&cPath=550_554
Old 02-19-2017, 12:29 PM   #16
73amc
What did you use to mount the coil up top?
Old 02-19-2017, 12:31 PM   #17
73amc
Originally Posted by 55superbeetle View Post
I just had these up on my phone. Would have to add a shock mount to the back like yours. I gotta find out what part number those coils were lol.
Old 02-19-2017, 07:18 PM   #18
73amc
Who owns the car now? Someone on here? Would like to track down the part number for those qa1
Old 03-08-2017, 10:37 PM   #19
cosbySweater
cosbySweater's Avatar
http://forums.turbobricks.com/member.php?u=54316
1995 Porsche 993
2013 VW Passat TDI
