Old 02-11-2019, 06:10 PM   #1
Ilvmetal
Default Ford 8.8 who's running c-clips eliminators?
Looking for ideas on running rear disks for my 8.8 rear setup with c clip eliminators.
My local track requires running c-clips eliminators for 10 sec and less cars.
We got twins from On3 performance on a LH6 ls motor so good brakes at 130+ is a must.
Any 8.8 owners running c clip eliminators?
here a pic of what I got so far;
1973 142 Turbo 8V build
1988 740 16V money pit
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 02-11-2019, 06:12 PM   #2
Ilvmetal
Old 02-11-2019, 10:01 PM   #3
cosbySweater
cosbySweater's Avatar
That's what disk brakes are for
1995 Porsche 993
2013 VW Passat TDI
Old 02-11-2019, 10:54 PM   #4
Ilvmetal
Looking for advise, you run OEM c clips in your 8.8?
NHRA wont allow them
Old 02-12-2019, 02:55 AM   #5
cosbySweater
I mean. What are you planning on doing with the car? I run OEM cclips on both of my cars, have taken them to the drags and never had them checked. Are you planning on doing powertour or something?
Old 02-12-2019, 05:50 AM   #6
2fast242gt
Do you have a cobalt?
I dont run them and I drag race all the time, I'll be in the 9's this year with ease.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 02-12-2019, 09:52 AM   #7
Ilvmetal
We it's not me but my local track rules states:
"Any car on slicks must have a driveshaft loop, C-clip eliminators and long wheel studs"
So Slicks are a must and the eliminators will be the first thing they look for. I guess a couple of years ago a big block Buick with c clips lost a axle in the crowd and almost killed some poor bastard.
Thinking i'll start with some ford cobra disk's and take some measurements.
Old 02-12-2019, 09:53 AM   #8
Ilvmetal
NY is as uptight and lawyer hungry as it gets. These are track rules and not mine;
Old 02-12-2019, 07:44 PM   #9
Ilvmetal
https://www.youtube.com/watch?v=fGkG8ggDnSc
Old 02-12-2019, 11:29 PM   #10
freevolvos
freevolvos's Avatar
T the buick had drum breaks that will let the tire and axel go flying
Old 02-13-2019, 08:24 AM   #11
Ilvmetal
Yes but still need them....
Old 02-13-2019, 09:08 AM   #12
freevolvos
freevolvos's Avatar
There good to have I have them in my 12 bolt
Old 02-13-2019, 10:43 AM   #13
aplitz
Donuts on your lawn
aplitz's Avatar
This is why I’ve never understood swapping to a c-clip 8.8 from a semi-float Volvo axle. The 8.8 is an ok axle, and stronger, but c-clips are such a liability, and for not much more money you could have speced out a 9” that is better in every way. I know that doesn’t help now, but something I’ve never grasped.
aplitz is offline   Reply With Quote
Old 02-13-2019, 12:21 PM   #14
freevolvos
freevolvos's Avatar
8.8 is cheap in the yards and easy to find funny thing is it looks like a 12 bolt chevy inside...It even uses some of the same bearings c-clip are just a method of axle retention, back in the drum brake days a broken rear end would allow the axle to fall out......a disc brake will stop that from happing now. As the rotor is trapped by the caliper The 9 inch and others use a pressed on bearing that bolts onto the end of the axle tube
Old 02-13-2019, 03:00 PM   #15
F*ck 12
Yeah there were 37 explorers in the local PNP's when I did my 8.8 swap. I found exactly what I was looking for 4.10 gears and traction lock LSD. $150 out the door with the extra short axle slid in the housing.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 02-13-2019, 08:29 PM   #16
Ilvmetal
Holy cow!
being that i'm in Screw-york a rusted out on goes for $450.
Shoot me your yards numbers and i'll shoot down there next week!!
Old 02-13-2019, 09:18 PM   #17
aplitz
Donuts on your lawn
aplitz's Avatar
It really depends on how the axle breaks if the caliper is going to retain your wheel, and even if it does your time is limited. C-clip also means that the axle itself is the bearing surface for the weight of the vehicle. Semi-float moves the weight onto a bearing and a race. All the 8.8 gets you is a cheap c-clip axle with the wrong bolt pattern. The whole 8.8 craze both here, and in the Jeep world, is false confidence and false economy.
Old 02-13-2019, 10:10 PM   #18
2fast242gt
You think they are going to pull your cover and look?
Old 02-13-2019, 10:12 PM   #19
2fast242gt
Minus being heavier
Old 02-14-2019, 01:13 AM   #20
aplitz
Donuts on your lawn
aplitz's Avatar
Minus being heavier
Are you saying a 9" is heavier than an 8.8, because I'm sure the difference is negligible at best.
Old 02-14-2019, 01:31 AM   #21
2fast242gt
Yes it is, and what's so confusing about why they are desirable? 150 bucks, a superior bolt pattern factory lsd and good ratios the c clip issue isnt an issue.
Old 02-14-2019, 01:32 AM   #22
55superbeetle
Weld big ford 9" ends on the 8.8 and you can reuse the explorer disk brakes and eliminate the c clips. Strange makes a spool/axle package for 580 bucks. Any length 35 spline axles, steel spool, bearings, and studs. Never going to break that stuff.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 02-14-2019, 02:07 AM   #23
aplitz
Donuts on your lawn
aplitz's Avatar
If you want to actually go fast, c-clips are an issue. The 8.8 and 9" are very similar in weight when equipped the same, within 20 pounds, negligible.
Old 02-14-2019, 05:52 AM   #24
F*ck 12
They're only open Monday-Saturday. They have 33 explorers as of today.
https://www.fossupullit.com/locations/chesapeake-va/
Old 02-14-2019, 06:14 AM   #25
89_740Turbo
89_740Turbo's Avatar
A good friend of mine just did this to his v8 740 build. ill have him take some pictures for you and upload them here
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
