Old 09-15-2019, 12:30 AM   #1
Whitestorm
Whitestorm's Avatar
Question Unmarked 8V Camshaft?
Whats up fellow TB'ers? Just finished tearing down my 90' B230FT which I pulled from a 740 and I have this little mystery cam from it. It has no marking on the back or the front. Does anybody know how to identify a cam other than measuring it? I have the tools to take the exact measurements so if I have to resort to that, someone tell me how Volvo measured their cams and I'll figure it out!
Whitestorm is offline   Reply With Quote
Old 09-15-2019, 01:00 AM   #2
77volvo245
77volvo245's Avatar
looks like the cam is oil slug. I bet its marked under the oil.
STSmachining
Old 09-15-2019, 01:53 AM   #3
gsellstr
gsellstr's Avatar
Agreed. Also, stock cam looking at the lobes. Aftermarket don't usually have the raised section like the stock ones do. I'd guess maybe a VX given the different profile between lobes.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 09-15-2019, 04:34 PM   #4
Whitestorm
Whitestorm's Avatar
Nope, I scrubbed the crap out of it (after the pic's) and I still can't see anything!
Old 09-15-2019, 08:04 PM   #5
shoestring
shoestring's Avatar
There were slotted VXs?
Old 09-15-2019, 09:53 PM   #6
2turbotoys
Salaminizer
2turbotoys's Avatar
I just bought a new VX cam for a customer and it has no markings at all, anywhere. And it is slotted.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 09-16-2019, 02:46 AM   #7
Whitestorm
Whitestorm's Avatar
That would be a very nice surprise if this turned out to be a VX cam!
Old 09-16-2019, 08:29 AM   #8
iHateVolvoPeople
I recently pulled a cam from a 945T and there were no markings at the end of it where they normally are, however, something like "KLIII" or "KL2", "KL3" was scribed in it elsewhere. Cam looked very mild so I have no idea what it is. I was thinking a factory regrind T cam maybe
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 258k
'99 Camry A140E, 262k
'00 Camry A140e, 248k
The 2 party system is a mere distraction, and you're all falling right for it.
Old 09-16-2019, 02:35 PM   #9
sbabbs
sbabbs's Avatar
OR a KL racing 3 cam..
Old 09-16-2019, 03:18 PM   #10
iHateVolvoPeople
See I assumed just as much, but it's profile looked anemic at best. I didn't have much time to take any measurements but will do so in the future.
Old 09-17-2019, 04:05 PM   #11
Whitestorm
Whitestorm's Avatar
That's a super aggressive cam and its the one I want to eventually get. The plan is to pair it with their 8v Extreme manifold. I'll take a look at the rest of the cam when I get home and see if I can find anything. Otherwise, any things I need to know to "properly" measure a Volvo cam?
Old 09-17-2019, 04:52 PM   #12
shoestring
shoestring's Avatar
I shoulda specified. I know the ipd VX is slotted, but didn't know if there was a factory slotted piece...
Old 09-18-2019, 02:28 PM   #13
sbabbs
sbabbs's Avatar
We'll the thing is every 740 or 940 comes with a slotted cam if you didn't know 240 lover.. Volvo made slotted M,T,A,B,V. Etc..
Old 09-18-2019, 04:46 PM   #14
naterhater
naterhater's Avatar
I think the marking is cast into the shaft of the cam somewhere rather than stamped into the end
"It's probably fine!"
"If you find yourself doing it a second time, do it right this time"
'93 940 Turbo thread:
http://forums.turbobricks.com/showthread.php?t=288116
naterhater is offline   Reply With Quote
Old 09-18-2019, 05:09 PM   #15
I've had cams where the stamping is so lightly done it's very hard to see the marking. On aftermarket cams they still marked it in the same place as volvo. At least the enem and early IPD turbo cams and IPD euro grind cams were marked there.
FYI my early IPD turbo cam read PH1 since they were based on a cam from Mike Aaro. My IPD euro grind cam was an A cam.
Old 09-18-2019, 06:03 PM   #16
F*ck 12
I have a slotted A cam, let the bidding begin
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 09-18-2019, 06:19 PM   #17
redblockpowered
redblockpowered's Avatar
One please. (http://forums.turbobricks.com/showthread.php?t=351080)
I sell chips for LH 2.4!
Old 09-18-2019, 07:39 PM   #18
shoestring
shoestring's Avatar
I love this.
A, M, T, and V I knew. I have a slotted V in my 240, so take that, 940 plebe!
Old 09-25-2019, 02:15 PM   #19
klr142
Turbo, what?
klr142's Avatar
Or an M, they have different lobes as well.
Old 09-26-2019, 10:45 AM   #20
245gti
Adapting Stuff
245gti's Avatar
No sir. Most cams had the same casting marks and most were ground from the same blanks. Casting numbers will tell you nothing...
Dale
Old 10-02-2019, 02:51 PM   #21
IansPlatinum
IansPlatinum's Avatar
Just pulled what I believe to be a stock M cam from my 1992 245... no marking on the end.
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 10-02-2019, 03:00 PM   #22
iHateVolvoPeople
Look closer, I bet it's there.
Old 10-02-2019, 03:18 PM   #23
IansPlatinum
How much $$$???
Old 10-02-2019, 03:23 PM   #24
iHateVolvoPeople
How much $$$???
This wouldn't be TB if I didn't offer $14.99.
Did you already try using a wire brush to remove the inevitable sludge due to hispters and their 9 thousand mile OCI's?
Old 10-03-2019, 07:32 PM   #25
IansPlatinum
You were correct sir. It is there, just very lightly marked. The T in the T cam was much deeper.
