Old 10-30-2019, 08:48 PM   #1
golddayton101
Default 84 240 Turbo Clutch Kit
I’m ordering my clutch kit this week and wanted to know if I can use a Sach kit for a 700 series turbo and just use the Pilot/Throwout bearing off of a 240? I remember reading a thread years back about other options like an Rx7 or Saab kits.
golddayton101 is offline   Reply With Quote
Old 10-31-2019, 07:25 PM   #2
You can use a 740 turbo disc and pressure plate with the 240 throwout bearing only if your car has the dished flywheel. If you have a flat flywheel turbo car. Then you need a clutch to match up to the flat flywheel.
However, the dished flywheel bolts on without modification so that is an option so you can use the 740 turbo clutch.
Old 10-31-2019, 08:54 PM   #3
golddayton101
Can the flywheel type be verified through the VIN?
Old 10-31-2019, 10:46 PM   #4
More likely the build date or a look in the engine bay.
Old 11-01-2019, 12:43 PM   #5
Yes, as Ken points out. There are certain parts that were installed along with the bigger flywheel. Is your car a factory intercooled car?
The factory intercooled car has a small bracket for extra relays just in front of the battery. If so then you probably have the lager flywheel in there.
Old 02-12-2020, 05:01 PM   #6
golddayton101
I've looked at the front of the battery tray a didn't find any extra relays. I did find out that the intercooler was retro-fitted in 87' so it's not a factory intercooler car. Would it be safe to say that the standard 7XX m46 turbo clutch kits will work with no problem?
Old 02-12-2020, 05:58 PM   #7
That would mean it's been retrofitted and should have a flat flywheel clutch setup. I would recommend getting a dished flywheel and clutch setup which hold a bit more power than the stock flat flywheel turbo clutch. Mine didn't last very long when I intercooled my car and upped the boost to 10psi.
BTW the build date is on the drivers door.
Old 02-13-2020, 02:00 AM   #8
77volvo245
77volvo245's Avatar
this will work with a 8.5in flat flywheel
https://www.stsmachininginc.com/coll...2-daily-driver
STSmachining
Old 02-13-2020, 09:41 AM   #9
F*ck 12
I have a flat flywheel clutch setup from South Bend Clutch that's good for 330ft.lbs. I do have a T5 swap but I'm sure they can come up with something for a factory trans.
Edit, I would support STS with above setup though, they make some cool stuff for our cars
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 02-13-2020, 02:00 PM   #10
This is a great way to go. The flat flywheel is quite a bit lighter even stock. The engine revs up much better with it.
Old 02-14-2020, 01:20 AM   #11
golddayton101
The STS is a good option. Does it matter which 9” flywheel I choose to run? Later 240, 740/60?
Old 02-14-2020, 12:55 PM   #12
white855T
Flywheel only matters if you're using lh 2.4 which you are not.
