Old 02-18-2020, 09:05 PM   #1
Texas240
Prius Owner
Texas240's Avatar
Default 240 ABS and tone ring usability
Some 7-8 years ago in my younger and dumber days I removed abs thinking it was cool to not have it. (car is a 93 factory abs. G80 locker) Im working on gathering the rest of the parts needed to stick a C4 rear end in the wagon in the following months or year or at some point and the rear end casing/dana 36 does not have a tone ring like the 240 casing has. ABS will go in at the same time as the swap.
Question is, does the abs care how many teeth are missing in the tone ring to see slippage? I'll be running speedo signal from the VSS signal from the LS computer into a Dakota Digital converter box. Just need to know if anyone has any bit of info. If the abs doesn't care then I can stick a toothed ring on the driveshaft.
Thanks
93 245 LS Engine Swap Project
Old 02-24-2020, 11:26 PM   #2
Texas240
Prius Owner
Texas240's Avatar
nothing? Something? Bueller?
Old 02-25-2020, 12:18 AM   #3
culberro
culberro's Avatar
Tone rings on the front and rear need to match. Running it on the driveline makes this impossible.
Old 02-25-2020, 12:36 AM   #4
JohnMc
JohnMc's Avatar
Yep, you need the same number of teeth per tire rotation on all 3 circuits. If you put it on a driveshaft, it would need fewer teeth to account for the diff gear ratio. Which would be hard to arrive at exactly starting with 48.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-25-2020, 02:16 PM   #5
kyote
Living The Dream
kyote's Avatar
Just practice your threshold braking, you don't need the crutch!
Old 02-25-2020, 02:22 PM   #6
2manyturbos
^^ Yeah, be a real man. ABS and synchros are for pussies. A real man can double clutch and shift a non-synchro trans all day long at any speed. Technology is for sissies.
Old 02-25-2020, 03:24 PM   #7
kyote
Living The Dream
kyote's Avatar
Aron is twice the man that I am, maybe 3 times.
Old 02-25-2020, 03:28 PM   #8
2manyturbos
Lol.
Old 02-25-2020, 03:33 PM   #9
JohnMc
JohnMc's Avatar
Unplug that brake booster too.
*manly grunt*
Old 02-26-2020, 12:08 AM   #10
Texas240
Prius Owner
Texas240's Avatar
Dude.. Thats the nicest thing you've said to me in the 10-11 years we've known each other.... I now have confidence that I don't need abs.
