Old 04-27-2020, 08:47 PM   #1
WTF99
Default Help twin scroll exhaust manifold with one wastegate
Hi all,
I have a twin scroll exhaust manifold without line to the wategate but I need modify it because I make a external wastegate but I want make only one external wastegate.
I'm not welder if you can me show a maximum of detailed pics that I can show it at the welder is really appreciated.
And how make the good choice for the wastegate and how much boost or power can accepted the stock pistons from s b230fk from 97 ?
My exhaust manifold come from "Sweden Exhaust"
1588034537-20200408-111523.jpg - envoi d'image avec NoelShack
1588034988-20200409-202724.jpg - envoi d'image avec NoelShack
1588035019-20200409-195130.jpg - envoi d'image avec NoelShack
1588035054-20200409-201315.jpg - envoi d'image avec NoelShack
1588035112-20200409-202111.jpg - envoi d'image avec NoelShack
Thanks a lot for your help
Sorry for my bad level in english
WTF99 is offline   Reply With Quote
Old 04-28-2020, 12:38 AM   #2
WTF99
For the choice of wastegate is ok I have find
http://turbolabofamerica.com/what-si...e-size-to-use/
Old 04-28-2020, 10:46 PM   #3
doucheNozzle
doucheNozzle's Avatar
What turbo are you using?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 05-01-2020, 01:24 AM   #4
WTF99
A little
Old 05-01-2020, 04:20 AM   #5
Sparkles
In the thread where he wanted to drill a hole between the scrolls I think he said HX35.
Hopefully you will ask your welder to keep the two halves of the manifold separate until your single wastegate like this https://images.app.goo.gl/5kCuoQiccUpUYzco7
https://images.app.goo.gl/pszcpXg7SJtiEbHL9
What wastegate do you have?
Sparkles is offline   Reply With Quote
Old 05-01-2020, 10:25 AM   #6
Stiggy Pop
Stiggy Pop's Avatar
the header I have from RSI is a true divided twin scroll but with a single gate. Sorry I am not finding a picture looking down the throat of the flange. Basically the wastegate outlet bridges the two scrolls right at the collector. Not the most ideal configuration I know but my car is still faster than most people's so neener neener I don't care.
'79 242
943 pickup
Old 05-01-2020, 01:40 PM   #7
Tfrasca
Tfrasca's Avatar
No boost creep with this, even at low boost?
Old 05-01-2020, 01:49 PM   #8
Stiggy Pop
Stiggy Pop's Avatar
not a lick. I've never had less wastegate spring in it than ~13psi but it'll hold it all the way out no problem. True for the HX35 and the 7670. Tial 38mm MVS.
I've thought a lot about a new dual gate manifold with a t4 flange on it, and Tate and I have discussed some plans around it, but I'm not sure the juice is worth the squeeze considering I already HAVE this.
Old 05-01-2020, 02:10 PM   #9
Tfrasca
Tfrasca's Avatar
Damn. That makes me wish I'd stuck with one wastegate on mine.
Old 05-01-2020, 02:41 PM   #10
Stiggy Pop
Stiggy Pop's Avatar
in for a penny in for a pound!
Old 05-01-2020, 03:11 PM   #11
WTF99
Why this is best that direct the 2 in one ?
Maybe I go of a Gen V hyper Gate 45 from turbosmart
Old 05-02-2020, 03:35 PM   #12
cosbySweater
cosbySweater's Avatar
Weld it into the exhaust housing
1995 Porsche 993
2013 VW Passat TDI
Old 05-08-2020, 12:09 PM   #13
stevE85
Formerly 1983_242
stevE85's Avatar
This is exactly what I was thinking after reading first post. Seems to be a popular option for this situation.
1982 244-"Ivory Blanco" GM L33/5.3L, T56, Mcleod twin disc, Gen 2 billet 7875, 44mm gate, 2.50 Hot/Cold sides, LJMS Stg2 turbo cam, PAC springs, H2O/Meth, 9.5psi/@13*, Etc.
stevE85 is offline   Reply With Quote
Old 05-13-2020, 12:47 AM   #14
t8fanning
8v are still cool, right?
t8fanning's Avatar
No no no. You need as many TiAL wastegates as you can fit in there.
An MVS is more than sufficient for most redblocks. Ideally, if using one wastegate and a divided manifold, you should separate the wastegate runner all the way to the valve. But I'm in the same boat as Mike. Mine is a single runner starting at the collector and works fine.
1982 242 Turbo.
Old 05-13-2020, 02:20 AM   #15
Duder
Comes with a free Frogurt
Duder's Avatar
Just because something works doesn't mean it couldn't have been better...
Old 05-13-2020, 04:40 AM   #16
Tfrasca
Tfrasca's Avatar
Don't worry, my second brand new MV-s got here last week. After boost creep killed my B23, I'm not taking any chances. Although I do plan to block off on of the wastegates sometime to see if it still works. Just because I'm a glutton for punishment.
Old 05-13-2020, 08:27 AM   #17
Stiggy Pop
Stiggy Pop's Avatar
Can we use code TATE for 20% off at checkout?
IS NOTHING I DO GOOD ENOUGH FOR YOU?! I HATE YOU DAD!
Old 05-13-2020, 09:17 AM   #18
white855T
If you bought the header new from swedenexhaust, how come you didn't add wastegate option? Seems like this would have been the better idea.
Old 05-13-2020, 11:19 AM   #19
cosbySweater
Shhhhhhh ;)
Old 05-14-2020, 10:36 AM   #20
kyote
Living The Dream
kyote's Avatar
Ding Ding Ding we have a winner!
K.I.S.S.
Old 05-15-2020, 08:48 PM   #21
t8fanning
t8fanning's Avatar
Tyler is single handedly saving us in these tough times.
I wish. But that's above my pay grade.
