Old 04-30-2020, 08:34 AM   #1
hessam69
Default Smoke emitting when high beam pulled
Hi,
I have a 740 and when I turn on the high beam smoke comes from the switch. I can replace the indicator switch assembly but how do I know the problem isn't somewhere in the wiring to it?
Old 04-30-2020, 10:21 AM   #2
daniels740
If you pull it out, it may be worthwhile to give it a good clean using electric parts cleaner; you'd be surprised how often that works to fix bad electrical contact as well as other electrical issues.
daniels740 is offline   Reply With Quote
Old 04-30-2020, 01:07 PM   #3
apachechef
Burnt Sierra Madre
just get this if you run out of smoke:
Dammit, Lummert.
Old 04-30-2020, 01:35 PM   #4
Dirty Rick
Dirty Rick's Avatar
Another thing that could be a problem is if you have installed high output bulbs.
There is a guy that sells a kit to take the headlight load off the dash wiring.
https://www.wagonmeister.com/highvol...lightharnesses
Old 04-30-2020, 01:38 PM   #5
Dan
Watching the World burn
Dan's Avatar
700's are negative earth you ninny......
also, check ends of connectors in plug, probably corroded where wires are to connector...
Best bet is to install a relay kit like mentioned above.
1985 Chevy TPI V8 740.
Old 04-30-2020, 02:16 PM   #6
apachechef
Burnt Sierra Madre
Just hold bottle upside down you goofball
Old 05-03-2020, 10:27 AM   #7
Lazarus
Originally Posted by hessam69 View Post
Hi,
Smoke coming from the steering column? I suppose the high/low beam switch in the column could smoke, but I think that switch controls the headlight relay in the fuse panel. A lot more current is flowing in the headlight relay. Mine slowly melted the slot in the fuse panel and would have caught fire if I hadn't found it accidentally. Check your headlight relay as part of the job.
Lazarus
Lazarus is offline   Reply With Quote
Old 05-04-2020, 02:30 AM   #8
gottarollwithit
Cooks with motor oil
Clean the switch, check the relay....
Then buy a relay harness kit, or make one. Not sure how good those are in that link above, but a good relay harness will make your car a lot nicer to drive at night. Remember, full juice passes through your switch to get to the headlights. Quite a path it takes to get there. Juice directly from the battery and only using the juice from the headlight switch to kick the relay on, makes your lights brighter.
1988 740 turbo wagon/squishmobile!
gottarollwithit is offline   Reply With Quote
