Old 06-16-2020, 12:18 PM   #1
2JZFC
Default Question For the Turbo LS 24X Swappers
Is anyone using or considered the Hooker LS turbo manifolds setup?
https://www.speedwaymotors.com/Hooke...ld,320377.html
2JZFC is offline   Reply With Quote
Old 06-16-2020, 12:22 PM   #2
JohnMc
JohnMc's Avatar
240 series, or 24X vs. 58X? (heh)
I looked at them briefly, but (without ever trying to fit anything) thought that I'd have fewer issues with the steering going forward with the crossover pipe. Also, not much room going back down and out with the downpipe if you're not doing a fender exit. A crossover pipe coming up would take up room you might need for the downpipe.
In retrospect - something cast iron and spark plug access friendly would probably have been a better choice.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-16-2020, 12:36 PM   #3
MikeSr.
What, me worry?
MikeSr.'s Avatar
Nice setup- a/c compressor would have to be removed or relocated.
I coulda had a V8!
Old 06-16-2020, 09:05 PM   #4
2JZFC
Yeah, it seems the crossover pipe would definitely cause a clearance issue with the DP, especially if it's 4" or 3.5". MOF, for me, room for a DP is one of the drawbacks of this swap, probably because I am not a fan of the DP routed high against the strut tower. Fender exit is an option and I have one on a street-driven drag fox body but it just doesn't seem appropriate for a Volvo
Old 06-16-2020, 10:05 PM   #5
JohnMc
JohnMc's Avatar
The suspension/crossmember is limiting the forward placement of the DP, and there's a starter there as well, eating up room. Seeing how snug my DP was in that area, I can't imagine where a crossover coming up would fit in there as well.
I actually used some 3" oval piping in that area. Round from the turbo, high past the strut tower and over the headers, then to 3" oval as it dropped down by the motor into a 90 degree bend, then back to 3" round. And even then with it heat wrapped, I had to add a sheet metal heat shield to the starter.
Old 06-17-2020, 08:37 AM   #6
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Denmah approved:
https://fahlersp.com/products/c-t4-t...ed-small-block
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 06-19-2020, 04:19 PM   #7
cosbySweater
cosbySweater's Avatar
I used the hooker turbo manifolds on my gremlin. The crossover didn't fit so I made my own but they are a nice piece. I'd say though the provided crossover probably will not fit on a 240. It's pretty wide
1995 Porsche 993
2013 VW Passat TDI
