Old 09-20-2020, 08:16 PM   #1
Bigjake34452
Default Replacing factory style RSR with common modern 4 pin relay
is This not common practice? Mine is bad, I see many many posts ending up with RSR being bad and seems like the better thing to do is to use a standard 40 amp relay available everywhere.. are there others who have done this
Bigjake34452 is offline   Reply With Quote
Old 09-20-2020, 08:38 PM   #2
I'm sure plenty of people have changed the relay to the more common spade terminal type of relay. The stock relay is also pretty cheap though so it's easy to stash a spare.
Old 09-20-2020, 08:57 PM   #3
2turbotoys
Astro Zombie
2turbotoys's Avatar
Are you referring to the fuel pump relay?
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 09-20-2020, 09:29 PM   #4
iamrolling
The RSR is in the engine bay. It controls whether the injectors get power, supposedly to prevent interference with the radio.
1993 940 Turbo (Mostly stock)
WARNING: I am not a professional mechanic, and you should only base your repair decisions on my advice if I'm not corrected by someone who has worked on more than a few Volvos.
iamrolling is offline   Reply With Quote
Old 09-20-2020, 09:56 PM   #5
2turbotoys
Astro Zombie
2turbotoys's Avatar
Ah, suppression relay. Thanks, didn't know the acronym.
Old 09-20-2020, 10:04 PM   #6
philski o'flood
philski o'flood's Avatar
it's just some 7/9 junk
philski o'flood is offline   Reply With Quote
Old 09-20-2020, 10:12 PM   #7
2turbotoys
Astro Zombie
2turbotoys's Avatar
Anytime a relay is a repeat offender, I wire a new relay next to it. Use the original relay to turn on the new relay so no real current goes through the problem relay. Extra wires, but ends the problem almost always.
Old 09-20-2020, 10:55 PM   #8
iamrolling
This one tends to do well unless it corrodes. Or the waterproof bullet connectors on the harness fall apart. But you can pop it open and clean it up like most other relays in the car. The silicone on the bottom of the relay fails and water gets in.
If you do replace it with a generic relay, make sure to get a waterproof relay socket for the same reason. But the specific RSR is very cheap new, if you can't save it by reflowing or cleaning it. And the harness connector is fixable with parts as common as (and cheaper than) waterproof relay sockets.
The harness side connectors can be replaced with generic 3.5mm waterproof female bullet terminals, if you don't feel like buying the correct pigtails. They won't be a perfect fit with the plastic retainer but won't interfere with it. And it will still be water resistant. If the wires aren't damaged below the terminals, you might be able to avoid using butt splices.
Old 09-20-2020, 11:38 PM   #9
Dan
Watching the World burn
Dan's Avatar
I replaced the rsr with a 40 amp relay in the 765 Hoovie wagon about 6 years ago,
1985 Chevy TPI V8 740.
Old 09-20-2020, 11:46 PM   #10
iamrolling
How did you splice it to the harness? I had to make a set of pigtails, and attach them to the harness with crimps which I filled with UV glue. I'm not proud of that one.
Old 09-25-2020, 02:01 AM   #11
Anders-R32
Cut the connectors of and put new spade's on.
google Volvo RSR relay and use the diagram for the new relay.
i just did this the other day.
Anders-R32 is offline   Reply With Quote
