iamrolling
- Nov 5, 2019
I shotgun replaced my coolant temperature sensor trying to stop the car from dumping so much fuel into the engine. I know, I should have tested it. But it cost next to nothing, and is one of those SU-5817s sold by AutoZone. I assumed it would work adequately and fit well.
It did work, and the exhaust smells much better. And I got it the old one out and new one in with much less trouble than expected. I removed nothing. Just stuck a 19mm deep well 12 point bolt rounder in there on a 3/8 ratchet, done in under 10 minutes.
The problems happened trying to plug it in. I push the connector onto the sensor, and the clip never retracted. You could just pull the harness connector right off with a slight tug. How did they screw up an EV1 connector so bad?
Not wanting to drain the coolant again, I went about modifying it in place. With a series of small files and razor blades, I shaved a bit off the end of the sensor's connector plastic and also the flat side of the tabs. I also removed the rubber rectangle from the bottom of the harness connector. After a painful hour, it finally clicked into place. Once again, I learned that I should have spent the extra few bucks for a Bosch part.
I can probably shave down the side tabs a bit more and fit the rubber piece back in, but that's where I have questions. Should I even put that thing back in? It's definitely failed, because the harness terminals were corroded when I found them. Is it possible to buy new ones that aren't so hardened? Could I just lightly paint the bottom of the connector with an RTV silicone, or would that cause other issues in the future?
